Lubricating Caliper Slide Pins - Honda-Tech
Old 11-23-2007, 02:00 PM   #1
ButterBall's Avatar
Default Lubricating Caliper Slide Pins
I was just wondering what, specifically, people are using to lubricate the brake caliper slide pins on their front calipers with?
I tried using some permatex brake specific lube, and it kept gumming up.
This one:
The service rep at my local honda dealer told me that they used Wurth silicone grease.
This one:
Parts wouldn't sell me a tube of this grease, but gave me a half finished tube to take. The parts guy told me the Wurth silicone lube would work, but they usually use Molyslip AS/40 for lubing caliper slide pins.
This one:
This was all after I went into the Honda dealership to buy some Polyurea grease (honda P/N 08798-9002) for lubing the pins. I've read on this forum that it's good for this purpose.
ButterBall is offline   Reply With Quote
Old 11-23-2007, 02:02 PM   #2
Resident Gearhead
BryanM.'s Avatar
Default Re: Lubricating Caliper Slide Pins (ButterBall)
I use Lucas hi-temp grease (green in color ). Has never gummed up on me.
BryanM. is offline   Reply With Quote
Old 11-23-2007, 02:59 PM   #3
Unceasing Measure
Archidictus's Avatar
Default Re: Lubricating Caliper Slide Pins (mcvtec)
Silicone gel is what I use.
Archidictus is offline   Reply With Quote
Old 11-23-2007, 04:05 PM   #4
318 Curves, 11 miles
Vindicator9000's Avatar
Default Re: Lubricating Caliper Slide Pins (Archidictus)
A little offtopic, but has anyone had a slide pin completely seize up? One of mine is frozen, and I can't get it in or out to clean/relube it.
Vindicator9000 is offline   Reply With Quote
Old 11-23-2007, 05:44 PM   #5
Echo7847's Avatar
Default Re: Lubricating Caliper Slide Pins (Vindicator9000)
I personally use a product called Sil-Glide @ work on slide pins. Its just a silicone lubricant in a gel form and comes in a tube the size of toothpaste.
Quote:
After they become seized you can usually break the pins loose but they will seize again no matter how well you are able to clean it. Once this happens we usually recommend replacement.
Echo7847 is offline   Reply With Quote
Old 11-23-2007, 05:49 PM   #6
Chiovnidca's Avatar
Default Re: Lubricating Caliper Slide Pins (Echo7847)
We use the sil glide too. Works great and doesn't swell up the rubber boots like petroleum based lube does.
Chiovnidca is offline   Reply With Quote
Old 11-23-2007, 05:58 PM   #7
Froth's Avatar
Default Re: Lubricating Caliper Slide Pins (Chiovnidca)
I've always used Permatex Ultra High-Temp(Red label) and I've yet to see a single problem with it.
-Froth
Froth is offline   Reply With Quote
Old 11-23-2007, 08:46 PM   #8
Quote:
Replacement of the pin, or the whole caliper mounting bracket?
Old 11-23-2007, 09:11 PM   #9
Tarmac Junkie's Avatar
To lube the pins I use permatex anti-seize (silver bottle)...
Tarmac Junkie is offline   Reply With Quote
Old 11-23-2007, 09:52 PM   #10
timmybilt's Avatar
i have had this happen on nearly every honda i have ever bought so im pretty familiar with fixing it. i usually end up taking the caliper bracket off and clamping the pin in a table vise and working it back and forth until i can get it out (some are more stubborn than others) then use pb blaster to lube the pin and hole and work it until it moves freely then pack it with urea grease and re-assemble. replacement parts such as caliper brackets are not usually stocked so this method is a quick solution so you can get back on the road
timmybilt is offline   Reply With Quote
Old 11-24-2007, 04:37 PM   #11
Froth's Avatar
Default Re: Lubricating Caliper Slide Pins (timmybilt)
Quote:
That's how I've always done it, works good and if you're adamant enough about cleaning all the rust/gunk off the slide you can usually save the caliper bracket/slide this way. Did this for my friend on his S13 240sx and to this day he's had no problems.
-Froth
Old 11-24-2007, 05:23 PM   #12
t0p_sh0tta's Avatar
Default Re: Lubricating Caliper Slide Pins (Tarmac Junkie)
Quote:
t0p_sh0tta is offline   Reply With Quote
Old 07-03-2009, 12:08 PM   #13
ButterBall's Avatar
I came across the part #'s for all of the Honda brand lubricants. Including Honda brand silicone grease for brakes. I figured I would post up the list in case anyone else was interested.
http://img268.imageshack.us/i/hondalubricants.jpg/
DIY: How to Remove and Lubricate Disc Brake Sliding Pins (VIDEO) ProStreetDriver Tech / Misc 0 05-13-2016 10:06 PM
What lubricant for caliper slide pins? TOO MUCH TORQUE Tech / Misc 26 10-13-2015 07:36 AM
Lubrication Points on CRX Rob. Honda CRX / EF Civic (1988 - 1991) 1 06-25-2014 11:02 AM
Can I use this for brake caliper slide pins? rasinhell Honda Civic / Del Sol (1992 - 2000) 2 12-02-2007 04:33 PM
Using Hi-Temp Brake Fluid? Perhaps you need some Hi-Temp Caliper Pin Grease descartesfool Road Racing / Autocross & Time Attack 9 06-28-2006 01:42 PM
Tags
antiseize, brake, break, caliper, calipers, frozen, grease, honda, loose, lubricant, lubricating, pin, pins, slide, slider, slides
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
