LS swap mount question
Im putting a ls in my ek, I dont have any mounts. I know there not the best choice but im on a budget and will upgrade them later, will these be a straight drop in? http://www.ebay.com/itm/96-00-CIVIC-...ht_3739wt_1010
Re: LS swap mount question
yes they will work. But you'll need a t bracket also from a 99-00 si. but you may be able to find something on here for you budget.
Retired Moderator
hard race makes decent mounts as OE replacement that work great
http://www.velocityshop.com/product/...civic_326.html
he wont need to replace those mounts they will work fine.. only thing about them is the paint is cheap and chips over time of torque and twist.
I wouldn't run anything but OEM or Hasport mounts. I have seen cheap eBay mounts snapped in half due to stress over time. I have had numerous issues with Innovatives. I love my Hasports however.
You can reuse all rubber mounts assuming they are still good for the D16 that was in the EK. Also you need the rear trans T mount bracket and a 99-00 Si drivers side mount bracket, it is by the timing belt behind all the covers. I did this swap in my 98 HX and made it fully OBD2 at first. OM me if you have any question as there is a bit more to it that just a drop in, while it is a very easy swap. Some wiring changes ect.
i know on the ef's they made cheap mounts that did not have gussets and the trans mount hangs low and tends to snap. if u know someone that can weld u can make them work. but these ek mounts d and b series mounts wont snap.
