Low Idle, Sometimes Stalls - Honda-Tech
Old 08-10-2010, 11:36 AM   #1
Default Low Idle, Sometimes Stalls
98 Civic d16y7.
Just finally figured out why my car wouldn't start, and now that I got it starting again, it's idling really low/choppy. Could this be a clogged PCV valve? Or maybe a failing IACV? The air filter is clean and it accelerates normally.
The tach will rest at about 150rpms (yes, one hundred and fifty) when coming to a stop, then it will bump itself up to about 500 and smooth out. Sometimes it stalls, sometimes it doesn't. When it does stall, it fires right back up, and idles normally, until I blip the throttle and then it starts getting lumpy again.
Any ideas?
Also, how would I get the ECM? ECU? to re-learn the idle?
Thanks
euphanom is offline   Reply With Quote
Old 08-10-2010, 11:49 AM   #2
Nichelson_Performance's Avatar
Default Re: Low Idle, Sometimes Stalls
lol yeah i am wondering the same thing, mine does it too but i always figured it was from my huge injectors that i really don't need
Nichelson_Performance is offline   Reply With Quote
Old 08-10-2010, 12:29 PM   #3
MeGotRoundEye's Avatar
Mine does that too. It's wierd because if I turn the AC on it will idle fine. I hope you figure it out because alot of people I know have this very same problem.
MeGotRoundEye is offline   Reply With Quote
Old 08-10-2010, 12:31 PM   #4
willpower102's Avatar
diddo on thsi problem
willpower102 is offline   Reply With Quote
Old 08-10-2010, 01:13 PM   #5
Try cleaning the IACV. Any CEL codes? How old are the plugs, wires, cap, and rotor?
Former User is offline   Reply With Quote
Old 08-10-2010, 01:46 PM   #6
i know mine does it when i have the heater on full blast and headlights on sometimes but not all the time. doesnt bug me much because it doesnt do it all the time just once in a blue moon. i dont have any cels either. it only happens when im coming to a stop sometimes. im turbo so i have bigger injectors as well.
apexi_rsx is offline   Reply With Quote
Old 08-10-2010, 02:44 PM   #7
Quote:
Not sure how old the plugs/wires/cap/rotor is, the only CEL code it's ever spit out is P0420. Which is probably my bad cat, or an o2 sensor, or both... I'm really hoping that I can get away with some aftermarket part instead of buying a brand new ultra expensive cat converter...
Old 08-10-2010, 02:56 PM   #8
Most likely the idle control valve. The Girl friends sol does the same. It needs a good cleaning out!
Togger is offline   Reply With Quote
Integra always stalling and low idle acuralovar Acura Integra 1 02-21-2011 10:34 PM
jdm b16a - white smoke when vtec hits & low/fluctuating idle badboss23 Honda Civic / Del Sol (1992 - 2000) 1 09-15-2010 11:21 PM
Start and stall problems on 1994 LX misterxhybrid Honda Accord (1990 - 2002) 1 07-24-2008 12:46 PM
d16z6 weird idle eghatch909 Honda Civic / Del Sol (1992 - 2000) 13 02-21-2007 12:47 PM
Low Idle when engine is cold but ok when warmed up? IACV maybe? typeeg Tech / Misc 7 07-04-2004 03:37 PM
Tags
2002, acura, car, classic, coming, harley, honda, idle, idles, low, realy, rsx, stall, stalls, stop, ultra
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
