Low-beam trouble
Low-beam trouble
So I got in my 93cx tonight and started driving to Shopko. The ride was looking kinda dark and i realized that both my low-beams were not working, but my high-beams were. So after getting flashed 100 times in my short drive i changed the fuses, thinking that that would do the trick, but that didn't work. I am going to check the bulbs tomorrow, but i don't think they would both go out at the same time. I took my cluster out the other day and have not used my head light since that, so i thought that might have something to do with the problem, and it also rained a lot so maybe something was affected by the rain, but that sounds unlikely. So what do you guys think? PLEASE HELP
Re: (redricer)
you could check you wires and plug connections also i found that my cx the plug for the bulb comes loose and the headlight goes really dim to the point where it looks like a parking light so i checked the connection and they went right back on bright as ever
check your FUSES. In my 96 CX there are 4. 2 for the low beams and 2 for the high. Even if one blows both lights go out. I blew one not too long ago and I had to leave my car over night at work.
Re: (redricer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redricer »</TD></TR><TR><TD CLASS="quote">Does it make sence that the highs beams work but the lows don't????</TD></TR></TABLE>
it makes perfect sense. you have H4 bulbs which are dual filament. one filament for low beam, one filament for high. one can blow without effecting the other. get new bulbs.
