Loud metal to metal sound on intial engine start in cold weather. - Honda-Tech
Old 12-15-2010, 11:27 AM   #1
ferio252's Avatar
Default Loud metal to metal sound on intial engine start in cold weather.
I have a D16Y7 automatic. Weather was a "cold for California" 45F or so. When I started, I heard what sounded like cylinders firing without oil. CLakaclakaclaka then went away. Honestly it was less then maybe a quarter of a second.
Does anyone else experience this in the morning after the car sits overnight? And a noob question, but when you put the engine into ON from Accessory w/o starting the car, does any oil at all squirt onto the block to prep the engine for initial startup?
Engine background: some 207K miles and engine oil changed religiously every 3K and checked level every week.
ferio252 is offline   Reply With Quote
Old 12-15-2010, 11:40 AM   #2
habib's Avatar
Default Re: Loud metal to metal sound on intial engine start in cold weather.
No oil is moved until you crank the engine, the only thing primed when the key is turned to the "on" position is the fuel pump
habib is offline   Reply With Quote
Old 12-15-2010, 12:19 PM   #3
AutoXer's Avatar
Pretty common in every Honda I've had experience with. It's a combo of typical 4cyl piston slap and the oil being a little sluggish when cold.
AutoXer is offline   Reply With Quote
Old 12-15-2010, 12:51 PM   #4
ferio252's Avatar
^ Thanks. It just sucks to hear first thing in the morning.
Old 12-15-2010, 01:08 PM   #5
8YourV8's Avatar
Damn, I wish 45F was considered cold here.
8YourV8 is offline   Reply With Quote
Old 12-15-2010, 01:18 PM   #6
It could also be the starter grinding on the flywheel, mine did that today. Just throwing that out there, if you can narrow it down to that?
Kmiller is offline   Reply With Quote
Old 12-15-2010, 01:29 PM   #7
8YourV8's Avatar
Quote:
I'd put my money on cylinder slap. Not really a huge issue; most Hondas do it. My Civic GSR and my Corolla both do it when it's under like 40 degrees out on the first start of the day. It's not like it's a continuous knock. If it were, then it would warrant a concern.
92 civic wont start in the morning or hot/cold weather!! lilgomez Honda Civic / Del Sol (1992 - 2000) 4 06-20-2009 05:13 AM
Suspension noise in cold weather? lunarone Honda Accord (1990 - 2002) 8 12-07-2006 12:58 PM
Starter cranking is slow bluskye Honda Accord (1990 - 2002) 9 12-24-2005 12:07 PM
Help troubleshoot noise for me ! Drag_On Tech / Misc 1 08-19-2003 02:34 PM
engine sounds change... cold weather.. happens to you???? USDM 4G VTEC Honda CRX / EF Civic (1988 - 1991) 16 02-14-2003 06:22 AM
Tags
accord, car, cold, engine, engines, generally, honda, loud, louder, metal, sound, start, starting, suddenly, temp, weather
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
