list of error code meanings - Honda-Tech
Old 01-29-2005, 07:04 PM   #1
sharky8513's Avatar
Default list of error code meanings
i was surfing the web and i came across a link..i searched for error codes on the archives and i couldn't find any..so i figured it might be useful to someone here's a list
Oxygen Sensor "A" (Primary)
defective circuit or unplugged
defective sensor
Oxygen Sensor "B"
defective sensor
MAP Sensor (Manifold Absolute Pressure)
defective sensor
CKP Sensor (Crankshaft Position Sensor)
defective sensor
mechanical problem disconnected
piping (except 94-95 Accord)
ECT Sensor (Engine Coolant Temperature)
defective sensor
TP Sensor (Throttle Position)
defective sensor
TDC Sensor (Top Dead Center)
defective sensor
9*
CYP Sensor (Cylinder)
defective sensor
* not a valid code for any throttle body injection Hondas, ** not a valid code for V-6 engines
10
IAT Sensor (Intake Air Temperature)
defective sensor
12
EGR Lift Sensor (Exhaust Gas Recirculation)
defective sensor
* not a valid code if car is not equipped with an EGR valve (some Civic models are not)
13
BARO Sensor (Atmospheric Pressure)
defective sensor
14
IAC Valve (Idle Air Control)
defective sensor
15
Ignition Output Signal
missing or defective ignition output signal
16
Fuel Injector System
defective fuel injector
17
VSS (Vehicle Speed Sensor)
defective sensor
19
Automatic Transmission Lock Up Control Solenoid Valve
defective solenoid valve
20
Electrical Load Detector
defective sensor
21*
VTEC Solenoid Valve
* not a valid code if car does not have a VTEC engine, ** not with V-6 engine
22*
VTEC Oil Pressure Switch
defective oil pressure switch
23
KS (Knock Sensor)
defective sensor
* not a valid code if V-6 engine
30
Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB
defective sensor
* not a valid code for 1996
31
Automatic Transmission Signal "B"
defective sensor
41
Primary Oxygen Sensor Heater
circuit malfunction
43
Fuel Supply System
defective or malfunctioning fuel supply system
45
System Too Lean or Too Rich
malfunction in the fuel monitoring systems
48
LAF Sensor (Lean Air Fuel)
defective sensor
54
CKF Sensor (Crankshaft Speed Fluctuation)
defective sensor
58
TDC Sensor 2 (Top Dead Center)
defective sensor
* with V-6 engine only
61
Oxygen Sensor, Heated - Sensor 1 (Primary)
high voltage, low voltage, or slow response
63
Oxygen Sensor, Heated - Sensor 2 (Secondary)
65
Oxygen Sensor Heater (Secondary)
malfunctioning or defective oxygen sensor heater
67
Catalyst system Efficiency Below Threshold
malfunctioning or defective catalyst system
70
malfunction with the automatic transmission controls
71
Cylinder 1 Misfire or a Random Misfire
a condition is present that is
creating a cylinder misfire
72
Cylinder 2 Misfire or a Random Misfire
73
Cylinder 3 Misfire or a Random Misfire
74
Cylinder 4 Misfire or a Random Misfire
75*
Cylinder 5 Misfire or a Random Misfire
* valid code for V-6 engine only
76*
Cylinder 6 Misfire or a Random Misfire
80
insufficient flow detected
86
circuit range / performance problem
90
Evaporative Emission Control System
leak detected in the fuel tank area
91
Fuel Tank Pressure Sensor
low input
92
insufficient purge flow
the link is this 1 if you guys wanna modify it and archive it or whatever
http://www.ag-eng.com/ecu_ec.htm
sharky8513 is offline   Reply With Quote
Old 01-29-2005, 07:05 PM   #2
perlmeister8's Avatar
Default Re: list of error code meanings (sharky8513)
perlmeister8 is offline   Reply With Quote
Old 01-29-2005, 07:09 PM   #3
sharky8513's Avatar
Default Re: list of error code meanings (perlmeistere81)
well that showed me hu
Old 01-29-2005, 07:12 PM   #4
Soccerking3000's Avatar
thanks for the effort but its the VERY FIRST link in the eg+ forum lol
Soccerking3000 is offline   Reply With Quote
Old 01-29-2005, 07:13 PM   #5
sharky8513's Avatar
Default Re: list of error code meanings (Soccerking3000)
oh wow i guess next time i should skip the search and try to just look on the forum thing hu ...sigh
Old 01-29-2005, 07:14 PM   #6
sharky8513's Avatar
since so many people are visiting here could u guys take a look at this post of mine and help me out? thx! http://www.honda-tech.com/zerothread?id=1131705
Old 01-29-2005, 07:14 PM   #7
Maginnovision's Avatar
You know what's even better? If you buy the OBD readers they come with programs that have the codes for all the different cars. You type them in, and they'll give you what it means.
Maginnovision is offline   Reply With Quote
Old 01-29-2005, 07:30 PM   #8
sharky8513's Avatar
Default Re: (Maginnovision)
nice!
Old 01-30-2005, 08:48 AM   #9
sharky8513's Avatar
Default Re:
bump bump come on people if you come in here help me out and take a look at this link
http://www.honda-tech.com/zerothread?id=1131705 thx!!
Old 01-30-2005, 09:22 AM   #10
71.192.16.183
Default Re: Re: (sharky8513)
This is a little more "detailed" than the codes provided in the ECU codes sticky and I pm'ed this thread to JDMLifestyle so maybe he could add it.
Having the code as well as some of the causes > just having the code.
jlacoy82 is offline   Reply With Quote
Old 01-30-2005, 10:54 AM   #11
sharky8513's Avatar
Default Re: Re: (jlacoy82)
thanx!
Old 02-01-2005, 03:51 PM   #12
sharky8513's Avatar
bump so you can take a look and see if you can help me with my problem
Old 02-05-2005, 09:25 AM   #13
sharky8513's Avatar
just trying to keep it on my recent topics
Check Engine Light codes (CEL) Diagnostic Trouble Codes (DTC) Malfunction Indicator Light (MIL) and MuthaFodder Honda Accord (1990 - 2002) 55 02-15-2016 06:18 AM
CEL code write-up prelude_93vtec Honda Prelude 1 09-22-2007 01:47 PM
Just installed my Type R header a week ago and now CEL is on. SSBlueDC2 Acura Integra 3 07-25-2003 01:23 PM
howdo i fix my CEL? wm5holla Tech / Misc 20 07-10-2003 10:40 AM
installed Kenji p28 ecu and threw 2 codes? jonas Acura Integra Type-R 26 10-18-2002 07:59 AM
Tags
1996, acura, civic, code, codes, error, exhaust, flow, gas, honda, insufficient, list, meanings, recirculation, rl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
