Leaking Brake Fluid out the ABS
Hi guys, I have a 1994 honda civic 1.6L ex that is leaking brake fluid pretty bad out the bottom of ABS mnodule assembly. Do I need to replace the whole unit or can I just fixt it with new O ring or gasket? Is this a pretty common problem with this model?
Have replaced the O ring on the distributor shaft as it was leaking oil there, but is still leaking a little oil, and believe it is coming from the auto timing adjust module that mounts on the engine top right. Was told it has a O ring in it that can cause leaking oil problem. Anyone want to comment on this? Also it is leaking a little power steering fluid at bottom of resovoir, believe this is caused by hose from resovior to pump, need to replace the hose?
Thanks in advance!
Thanks in advance!
