knocking on hard turn
Old 03-22-2007, 09:05 PM
nonvtec92's Avatar
Default knocking on hard turn
what causes a knocking noise to come from your wheel well area on a hard turn? my car started doing this tonight coming home from work. may have been there for a while i guess, not sure. was driving home without the radio off and heard a pretty loud, distinct knock knock knock knock knock. kept knocking through the whole turn. is this a ball joint going bad?
thanks!
Old 03-22-2007, 09:06 PM
MR.johnson's Avatar
Default Re: knocking on hard turn (nonvtec92)
sounds like an axle.
only when your turning?
Old 03-22-2007, 09:07 PM
Econo Appliance's Avatar
Ouch. Check CV boots immediately.
Old 03-22-2007, 09:09 PM
ARMED's Avatar
yeah, im guessing the same thing...
axles
nonvtec92's Avatar
Default Re: knocking on hard turn (Econo Appliance)
cv boots look fine. i thought axles made more of a clattering sound? this is a hollow sounding knocking?
makes the sound ONLY when turning... to the left.
Old 03-22-2007, 09:12 PM
ARMED's Avatar
give it a little tug...
see if its loose (axles)
or maybe, you got some loose nut or something..
jack it up and start checking your suspension/axles
Old 03-22-2007, 09:16 PM
sweetEK's Avatar
had same problem on my hatch jacked it up found out that both cvboots were torn and needed to be replaced.. fixed em up now im good to go !
Old 03-23-2007, 07:15 AM
nonvtec92's Avatar
Default Re: (sweetEK)
axles all look good. none of the boots are torn or even have any slack in em. axles still look nice and tight. i can't shake em or pull em in and out at all...
what does a bad ball joint sound like?
Old 03-23-2007, 07:18 AM
ARMED's Avatar
sometimes even tho the boots are still good...the bearings inside are done....
Old 03-23-2007, 07:52 AM
nonvtec92's Avatar
Default Re: (ARMED)
hmm... when ball joints go bad do they make any noise or do they just come apart/break?
thanks for all the quick resonses, really appreciate it.
just wondering if there's anything that will knock when turning other then axles.
appreciate it!
Old 03-23-2007, 07:59 AM
sniggler316's Avatar
Default Re: (nonvtec92)
Yes ball joints make a knocking sound. Mine is doing it right now! I thought it was my axle too, but I had my dad turn the wheel back and forth until it made the noise, and it is definitely the upper ball joint in my case. It sounds pretty much how you describe your noise.
Old 03-23-2007, 08:20 AM
New User
charjacq's Avatar
CV joint!
Old 03-23-2007, 09:07 AM
FalkenSiR's Avatar
if it's the axle, if the left side knocks, its the right axle, if the right side knocks, its the left axle
Old 03-23-2007, 09:34 AM
92ehatch's Avatar
Default Re: (FalkenSiR)
i had the same problem in the rear of my car. it was a wheel bearing gone bad.
if this is the front it could be, balljoints, axles, wheel bearing, anything suspension related pretty much.
Old 03-23-2007, 10:30 AM
nonvtec92's Avatar
Default Re: (92ehatch)
so how do you determine it's a bad ball joint? lift the car up and turn the wheel back and forth? it will only knock if i turn the wheel pretty far to the left. if i don't turn hard, it won't do it...
Old 03-23-2007, 12:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtec92 &raquo;</TD></TR><TR><TD CLASS="quote">so how do you determine it's a bad ball joint? lift the car up and turn the wheel back and forth? it will only knock if i turn the wheel pretty far to the left. if i don't turn hard, it won't do it...</TD></TR></TABLE>
That's exactly what mine did. I sat there turning it for like five minutes before I finally got it to make the sound. If you put your hand near there while it makes the noise, you can feel it pop.
Old 03-23-2007, 01:28 PM
Skunk.Werks's Avatar
Default Re: (sniggler316)
Get new axles
SleepyEF
Suspension & Brakes
06-07-2014 06:21 PM
D16Z6racing
16
07-15-2007 10:16 PM
HmgLauj69
01-04-2005 10:29 PM
RacerXI
08-17-2003 09:16 AM
90-CRXSi
08-19-2002 10:43 AM
Quick Reply: knocking on hard turn
