Knock Sensor Help
Knock Sensor Help
Putting an obd1 B18c1 into 94 Eh3 using eh3 engine harness (sohc vtec)
as far as i know i should be able to use this harness witch execption of the knock sensor, my harness is apart as i'm creating a tuck harness, is there a way to wire the knock sensor to keep this harness?
(hard line to ecu?)
or obviously a GS-R harness would work,
what should i do? as i'm running a p72 i'll throw a code not having one, correct?
(hard line to ecu?)
Re: Knock Sensor Help
(hard line to ecu?)
(hard line to ecu?)
Thanks for the help. that shouldn't be too bad, and i've been mocking up the harness i think i'll be fine. if any thing, i'll be shortening alot. And only slightly off topic but do i need to keep the EVAP sensor on the top of the intake manifold (i deleted my canister)
Oh yeah i am running a stock GSR intake manifold.
