Poor mpg, pls help.
Poor mpg, pls help.
Ok, my dd is a z6 del sol auto, I had horrible mpg since I got the car, around 24mpg (22-26), but since I installed a short ram + hks mushroom filter my mpg dropped to like 15, not kidding! My car runs alittle better. Where can I start to look at? Other then putting stock intake back? What test can I do? It's got new cables, dizzy, oil change, New coolant but runs hot but does not overheat, has the delay in 1st and then it takes off, those are the symptoms and details , what can I do?
Re: Poor mpg, pls help.
Daaaaaamnnnn 24's bad enough in a Z6 even if it is an auto. But 15?! Something is seriously wrong here, and not something small like air in the tires. I can't even see a short ram/hks filter doing anything to decrease mpg.
i had 1/2 tank, drove about 30 miles, and im a little less than 1/4, i have to wait until i run out to see exact miles out of that tank, but i noticed the drastic drop and by my calculations i came up with 15.
Naw man you don't have to go through all that. Just fill up your tank, reset your trip to 0, drive a hundred miles or so, go refill the tank, see how many gallons you fill back into it and divide that into how many miles are on the trip and you'll see how many miles per gallon you get.
all that was replaced no more than 3 weeks ago, i drive 95% freeway, no cel, i drive 3k to 5k, freeway 3k at 70miles, to start i try to kick it to 5k+ because anything lower dont move me, only thing i havent changed is sparks.
I dint know a better way to get the mpg, ima try that asap.
change ur fuel injectors, i had that problem when i swapped my b16, i swear i was getting 15 miles to the gallon to, then i was suggested to change em and it runs a lot better mpg
All guys have given good info so far except cali-boi, I would change my spark plugs first and for most (make sure to gap them correctly) then change the fuel filter. Probably get a fuel system cleaning and if worse case get the injectors cleaned. (there is places that clean and blueprint injectors pretty cheap) Last resort is buy new injectors, any other causes should turn on ur CEL (if ur CEL bulb is working that is)
ReplAced plugs with ngk's. Old one r as follow.
1. Even grayish white and gray/yellow top(the leg)
2. White on one side, purple ish the other, gray yellowish top(leg)
3. White bottom and purple upper part, gray yellowish top(leg)
4. Darker purple with one white spot, yellow top(leg)
I haven't driven the car yet, but based on that what do you guys think?
What injectors did you have and what injectors you have now? I swapped in a B16 but kept my OBD1 injectors off my stock Civic CX. I have horrible gas mileage also.
WOW joelmatt that injector place where u live is ripping u off, the one here only charges $25 - $40. Well kiana did replacing the plugs help at all?
got ma self some nkg plugs and did the mpg with the full tank and im getting 26mpg!!!! i still have to clean the injectors just in case. no cel.
thanks all of you!
thanks all of you!
