jrsc em1 need help misfiring
Old 12-29-2009, 07:39 PM
bossm's Avatar
Default jrsc em1 need help misfiring
yea well i have a 2000 honda civic si with a jackson racing supercharger at 9 psi the car has 160000 miles but i ran good anyway i drove it and parked it and turned the car back on after sitting there for a hour or two and the idle was just really misfiring and now its real bad at idle it will misfire once every three seconds and when i try to drive the car it just sputters at 15% or more throttle im not throwing any codes but i did throw a code once but it rurned off by itself and when i hook up my laptop to the hondata s300 it doesnt show any codes even tho it sputters and misfires when it did hrow the code it told me injectors but i replaced them and it still does the same thing i checked the resistor box and everything is fine it also has brand new spark plugs and wires
please i need help car is a dd that has been sitiing for two weeks
Old 12-30-2009, 04:35 AM
bossm's Avatar
Default Re: jrsc em1 need help misfiring
please help
Old 12-30-2009, 06:32 AM
bossm's Avatar
need help asap
Old 12-30-2009, 06:45 AM
B16acivicsedan91's Avatar
Check you plugs and do a compression test just for piece of mind.
Old 12-30-2009, 06:59 AM
Luserkid's Avatar
Check the spark plugs for sure. On datalog what does it show your timing to be at when it sputters? Do you have a wideband, what does that show when it sputters? Check cap/rotor/ignitor/dist.
Old 12-30-2009, 02:47 PM
bossm's Avatar
yea it has brand new plugs and wires and i checked the distributor it looks perfect and it ran real lean when it sputters but at idle its perfect air fuel ratio and it still misfires every few seconds
Old 12-30-2009, 07:38 PM
bossm's Avatar
anyone
Old 12-31-2009, 03:02 PM
bossm's Avatar
checked the distributor again today and it seems perfectly fine and i did a compression test and it came back 185-190 across the board can someone please try to help man im trying to take it on monday to a local shop but i would love to find out myself
Old 12-31-2009, 04:25 PM
Ricey_Bricey's Avatar
what kind of fuel setup are you running? do the spark plugs show your running lean or rich? make sure the injector plugs and wiring are good, this happened to my friend, thought he blew the motor only to find out it was a loose connection at the injectors.
Old 07-07-2011, 11:07 AM
xxstreetracer605's Avatar
set the motor to tdc take out distributor take off the cap and put the rotor to #1 plug and put it back in
i had same problem with my ek
Old 07-07-2011, 01:40 PM
The Grumpiest
grumblemarc's Avatar
Who are you talking to? I'm sure after nearly 2 years they've solved thier problems.
migrod1
04-04-2012 10:37 AM
michjdm
03-29-2012 08:02 PM
vgsr
06-21-2006 05:42 PM
EARLdaSQUIRREL
07-25-2004 01:15 PM
shahram72
12-19-2002 10:49 AM
Quick Reply: jrsc em1 need help misfiring
