installing RC injectors
Old 04-11-2005, 03:15 PM
Lmgrcivic's Avatar
Default installing RC injectors
has anyone had any problems with the rubber rings that sit in the intake manifold and the injectors sits in then I have a skunk2 manifold and the rings are to big to fit in the manifold when the injector is in it
Old 04-11-2005, 03:47 PM
tur3oDC4's Avatar
Default Re: installing RC injectors (Lmgrcivic)
just silicone them in bump
Old 04-11-2005, 04:18 PM
Mr. Badwrench
boostedcivicsir's Avatar
it is a very tight fit, but if you use some 2+2 you can usually get them to go in. people have dremeled them out also but i htink if you try to push them they usually go.
Old 04-11-2005, 04:53 PM
Simple's Avatar
Default Re: installing RC injectors (boostedcivicsir)
i had to dremmel to get mine to fit on my b20Vtec motor i had
Old 04-15-2005, 10:03 PM
Lmgrcivic's Avatar
Default Re: installing RC injectors (Simple)
cool thanks thats what I figured but I just wanted to make sure I wasnt the only one
Old 04-15-2005, 10:24 PM
GSlowR's Avatar
what i did was took a little bit of motor oil and put them on the rings.. slides in much easier..
Old 04-16-2005, 12:18 AM
1heavy4dr's Avatar
lubercate em homeboy
Old 04-16-2005, 05:56 AM
-[95cxhatch]-'s Avatar
I had to use the dremel to take a **** hair width out of the seal and motor oil to lube that bitch in
dc2_build
11-09-2014 10:50 PM
JDM_Ej
08-08-2005 12:32 PM
SupaFly_Honda
06-15-2005 06:12 AM
ldanphanl
03-10-2005 08:59 PM
dustin
02-10-2002 09:49 PM
Quick Reply: installing RC injectors
