Installing the head 1.5L auto Problem?????
Old 04-07-2004, 04:02 AM
yellow93delsol's Avatar
Default Installing the head 1.5L auto Problem?????
It runs fine at idle but when i put it into gear it dies down when i give it gas. Any ideas? Timming ?
Old 04-07-2004, 04:05 AM
MikeNice's Avatar
Default Re: Installing the head 1.5L auto Problem????? (yellow93delsol)
I would check for a vacuum leak. It wont hurt to check your timing but I doubt that is the problem. Also check your fuel system, you might have a clogged fuel filter or something like that.
Check all your sensors, you probably forgot to plug one back in when you were putting the head back on.
Old 04-07-2004, 04:06 AM
Default Re: Installing the head 1.5L auto Problem????? (MikeNice)
ok thanks
Old 04-07-2004, 04:07 AM
MikeNice's Avatar
no doubt but really check your sensors.
Old 04-07-2004, 05:12 AM
scratchy's Avatar
well you probably have a vacume leak double check do you have a check engine light
Old 04-07-2004, 05:17 AM
el diablo
Built to Spill's Avatar
what year/code is the head? what year is the car? if you have an obd2 head on an obd1 block/ecu (vice-versa) could be problems there.....or could be fuel problems, running to lean/rich.
RandomNeeha
08-07-2009 07:52 PM
1 Fly SI
Audio / Security / Video
05-25-2007 04:58 PM
blueskiesfade609
03-06-2004 10:29 AM
EF4lyfe
02-01-2004 02:32 PM
chictunner97ex
07-17-2003 10:55 AM
Quick Reply: Installing the head 1.5L auto Problem?????
