Install Cruise control on my 99 civic HX
Re: Install Cruise control on my 99 civic HX
I just found this does anyone else know the wiring for this has anyone done any cruise control swap on civic's. The parts I have are the pedals that have the double throttle cables not single also I have the cruise switch and pigtail and do have the cruise control cable not sure if the z6 cruise control box that sits next to ps resovor will work but will try to make this work.. LMK if anyone else has any info.
Technical Hero
Heres an aftermarket writeup(these are EG but should be similar for both I'm assuming):
http://www.jasonandginny.com/OurWebs...secontrol.html
OEM:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/honda-civic-92-95-eg-eh-ej-oem-cruise-control-install-guide-%96-manual-transmission-2437528/#post36595023
OEM:
Oh look, I can change this
I've removed all the necessary parts for a 6th Gen before. I haven't done an install, but I found the removal to be easier than for a 5th Gen. Of course it helps to know what you're doing. However, I did use a few rough guides that are out there for 6th Gen Civics, which get you 90% of the way.
