HELP THEY BROKEN INTO MY CAR...
Old 02-21-2005, 09:26 PM
Ls-Turbo's Avatar
Default HELP THEY BROKEN INTO MY CAR...
sadly like so many other hondas they broken into mine 2000 si.. they tried to steal my car and broke my ignition .. and my climate control because they took my deck.. so I NEED A NEW IGNITION WITH THE KEY WHERE CAN I FIND ONE WHERE CAN I GET ONE INSTALLED BESIDES THE HONDA DEALER.. i can ever drive my car.. will post pics soon
Old 02-21-2005, 09:27 PM
BolivianFuego's Avatar
Default Re: HELP THEY BROKEN INTO MY CAR... (sokleanness)
Try Junk yards. You could probably find one with key and everything. Goodluck.
Old 02-21-2005, 09:28 PM
SOHC4life 96's Avatar
I'm pretty sure the only place you can have your ignition fixed is the dealer. You could try the junk yards but I dunno. Sorry about your car man. It seems the Si's are getting attacked even more these days.
Old 02-21-2005, 09:36 PM
ekb16's Avatar
damn thieves..got my ek broken into and they jacked my AEM intake but couldnt jack my deck tho..good luck.
Old 02-21-2005, 09:43 PM
cxSHOE's Avatar
i assume all you need is the igition housing the part which they probably broke off the steering column. or did they just mess up the key cylinger part only??
and just change out the key cylinder and you can still use your oem key. its best to get a new one only because the housing uses break off bolts on top of the steering column.
goodluck
Old 02-21-2005, 10:11 PM
Ls_V_TurboSi's Avatar
Default Re: HELP THEY BROKEN INTO MY CAR... (cxSHOE)
its pretty simple.. I buy alot of theft recovery cars so I've changed these probably 100+ times.. I can sell you an ignition for like 75 bucks all you have to do is take your lock thats in your broken ignition, slide it into the new igntion and the ignition itself is good to go.. Then on the top bolts that hold the ignition on just use a flat head screw driver to turn the bolt, you kind of have to angle it to get it get it to catch but just remove those bolts then go to honda and buy the 8mm break away bolts for like 3 bucks a peice and put it back on..
Old 02-21-2005, 11:17 PM
Ls-Turbo's Avatar
Default Re: HELP THEY BROKEN INTO MY CAR... (Ls_V_TurboSi)
intresting... i kinda get the idea of wat your talking about.. so its kinda of a do it urselfer eh..?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls_V_TurboSi &raquo;</TD></TR><TR><TD CLASS="quote">its pretty simple.. I buy alot of theft recovery cars so I've changed these probably 100+ times.. I can sell you an ignition for like 75 bucks all you have to do is take your lock thats in your broken ignition, slide it into the new igntion and the ignition itself is good to go.. Then on the top bolts that hold the ignition on just use a flat head screw driver to turn the bolt, you kind of have to angle it to get it get it to catch but just remove those bolts then go to honda and buy the 8mm break away bolts for like 3 bucks a peice and put it back on.. </TD></TR></TABLE>
Old 02-21-2005, 11:19 PM
cxSHOE's Avatar
if you look at it there is a small pin hole at the top of the assemby and you put your key and turn it once and you push down on this pin hole and the ignition tumber comes right out, and that is the part that you switch out with the new/used one you get
Old 02-21-2005, 11:26 PM
hondatheart's Avatar
Damn sux about you car man, I feel your pain...well about your ignition your best beat would probably be the dealer, but you should shop around online the best prices are usually on the net, check out froogle.com you can search for things your looking to buy, its by the people who made google.com.
Old 02-22-2005, 02:39 PM
Ls-Turbo's Avatar
bumpin
Old 02-22-2005, 02:59 PM
As long as I dont have to take out any more Metal Gears
rukawa1one's Avatar
Damn i wish i knew that like 5 years back. I got two keys, one for door, one for ignition. But i have an alarm so i dont use the door key that often.
Old 02-23-2005, 02:44 AM
Default Re: HELP THEY BROKEN INTO MY CAR... (rukawa1one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one &raquo;</TD></TR><TR><TD CLASS="quote">
Damn i wish i knew that like 5 years back. I got two keys, one for door, one for ignition. But i have an alarm so i dont use the door key that often.</TD></TR></TABLE>
I dont know how important it is to have them all matching... If you pull your cylinder lock out of the igntion and take it in to a locksmith with your door key they can switch the internals of the lock to match the key for the doors. Its a real simple process and they charge about 10-15 bucks.. Just call around to get the best price
Old 02-23-2005, 12:30 PM
Ls-Turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls_V_TurboSi &raquo;</TD></TR><TR><TD CLASS="quote">I dont know how important it is to have them all matching... If you pull your cylinder lock out of the igntion and take it in to a locksmith with your door key they can switch the internals of the lock to match the key for the doors. Its a real simple process and they charge about 10-15 bucks.. Just call around to get the best price</TD></TR></TABLE>
thanks that sounds handy
Old 02-23-2005, 12:58 PM
Stunt101's Avatar
Theres a place called Accord Auto in Riverside they have ignitions with keys for less than $100 Call 411 for there number
Old 02-23-2005, 02:58 PM
Spoon DelSol's Avatar
where are u from if your around louisville kentucky i will key it for you for free its real easy
Old 02-23-2005, 03:40 PM
JayDeeMDA9's Avatar
GO to H-Auto in westminster i got a DA ignition there for cheap
rugimpy
08-21-2012 10:12 AM
JDMequalslife
11
08-12-2012 03:01 PM
vware1955
09-30-2008 12:36 PM
wuhungsixxx
04-08-2002 03:54 PM
Quick Reply: HELP THEY BROKEN INTO MY CAR...
