I'm burning a full quart of oil every 600miles!
Old 06-22-2008, 01:32 PM
nonvtec92's Avatar
Default I'm burning a full quart of oil every 600miles!
Hey everyone...
Well my troubles all started a few months ago, when my radiator first sprung a leak. Replaced it, which led to a leaking radiator cap... replaced it, and then my upper radiator hose burst. Replaced it, and then my heater hose burst. All the while, my cap still leaking, even after replacing it with 2 new ones.
SO, I figured my headgasket was blown...
Replaced the headgasket, and everything was great. No more coolant blowing out of every orface... no smoking at all.
Now all of a sudden, i've started noticing blue smoke. I've noticed it a few times backing up... a puff of blue smoke when I rev it a bit. It smokes like crazy at HIGH rpms... most of the time, I can't tell anything. Although, mind you, i've never driven behind the car to really tell; but from the rear view mirror I only notice smoke if I rev it high (which I rarely do).
I've been keeping check on it, have put about 2000miles on the car since the headgasket was replaced. I noticed yesterday, the car was ticking a bit, so I checked the oil, and I was a quart low. It's been 700miles since I last checked the level.
My question is... what's wrong with the motor now??
I had my head deck shaved when I replaced the HG, and they supposedly checked everything, and replaced the *valve seals*? Has new camshaft oil seal. It's not leaking from anywhere.
Is there any way/test I can do, to find out what the problem is?
Thanks everyone!
Old 06-22-2008, 01:34 PM
BlueIntegraBoy's Avatar
Default Re: I'm burning a full quart of oil every 600miles! (nonvtec92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtec92 &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks everyone!</TD></TR></TABLE>
Rings are gone
Leakdown test
Old 06-22-2008, 01:37 PM
elektronsi's Avatar
Default Re: I'm burning a full quart of oil every 600miles! (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
Rings are gone
Leakdown test</TD></TR></TABLE>
x2
Old 06-22-2008, 01:38 PM
nonvtec92's Avatar
I'll go search about leakdown tests... anyone want to post how to do that incase I don't find anything?
Thanks for the quick response!
GSE980's Avatar
I would say your valve guides are shot causing oil to get into your cylinders and get burned
Old 06-22-2008, 01:45 PM
OMGWTFBBQ!'s Avatar
The leakdown test will tell you where your problem is. The solution is much easier from there on.
Old 06-22-2008, 01:46 PM
nonvtec92's Avatar
lol
Yeah, probably whether or not i'll be getting another longblock or not. I suppose I should just plan on it.
I'm not tearing this POS apart again.
Old 06-22-2008, 07:35 PM
Sol to Sol
JarvisW's Avatar
Default Re: (nonvtec92)
Leakdown test posts are in the FAQ.
Good luck, I have the same problem, and need to do the same thing.
Old 06-22-2008, 10:01 PM
.I.Need.Money.'s Avatar
Rings are gone
Old 06-22-2008, 10:37 PM
luvmihatch's Avatar
Default Re: I'm burning a full quart of oil every 600miles! (.I.Need.Money.)
leak down test will show u alot.. if u do teh leak down and air starts coming out of intake mani then intake valves are bad comes out exhust then exhust valves are bad comes out fo psv system then rings are shot.. but ima go with rings being bad bc when cold teh rings havent expanded yet.. do a comp test adn cylinder with lowest comp start leak down test there..
Old 06-23-2008, 05:31 AM
Former Moderator
B18C5-EH2's Avatar
Unfortunately when your engine overheats badly enough to blow the head gasket there is untold amounts of damage done to the bottom end too. The same levels of heat that warped the head's deck surface could very easily damaged miled-up rings as well.
I work at a shop and we have stopped doing head gasket jobs on cars with 150,000+ (sometimes less depending on how badly it was overheated) because of situations just like yours. Sure the head gasket is leaking, but now you need an engine anyways. It's hard to cgarge a customer over $1000.00 for a job only to have them need an engine anyways almost immediately when the bottom end starts oil smoking.
Sometimes rebuilding the head with new guides and valvestem seals actually makes the bottom end smoke faster/worse. It sucks man. It's a crappy situation, but it happens a lot unfortunately.
If you did the work yourself then hopefully you didn't dump too much money into the head gasket job.
Old 06-24-2008, 10:06 AM
nonvtec92's Avatar
Default Re: I'm burning a full quart of oil every 600miles! (B18C5-EH2)
Yeah... thanks goodness I did it myself. I wasn't sure if I was going to have time to do it so got quotes of $1200+ around here.
I guess i'll look around for a new motor!
jxhxb
17
06-27-2010 03:17 PM
corchado85
05-26-2007 09:44 AM
copsloveme
12-03-2006 02:11 PM
bretx0r
07-17-2005 10:39 PM
92integraVTECgsr
03-29-2005 11:02 AM
Quick Reply: I'm burning a full quart of oil every 600miles!
