Ignition switch wiring question. Please help.
Old 09-28-2004, 12:07 PM
Paragraph Alert
ActiveAero's Avatar
Default Ignition switch wiring question. Please help.
I apparently have a faulty ignition switch and do not feel like paying $200-250 to replace the entire assembly. The car will start, but as soon as you release the key it dies.
I've unplugged the ignition switch on the backside of the key input. It has five wires. I'm trying to figure out which set of wires keeps the engine running after being started. I'll be rigging up a toggle switch along with a push button for starting.
I have a volt meter, but no Helms manual to follow.
Any input on the function of each wire would be appreciated. Thanks.
Old 09-28-2004, 12:37 PM
Paragraph Alert
ActiveAero's Avatar
Default Re: Ignition switch wiring question. Please help. (HTechBB)
It's an EG (94).
Old 09-28-2004, 12:48 PM
project_mercy's Avatar
Default Re: Ignition switch wiring question. Please help. (ActiveAero)
functionally, here's how it works.
When the key's off, nothing's connected (position O)
turn it to the first position (acc) it connects +12Vdc (WHT) to Accessory + (WHT/BLK).
If you turn it to the second position (run) it connects +12Vdc (WHT) to Accesory+ (Wht/Blk), Ignition Sys[your distributor] Power+ (Yel/Blk) and Systems Power+ (Yel).
Turn it to the third position (start) it connects +12Vdc (WHT) to Ignition Sys+ (Yel/Blk) and Starter Solenoid+ (Blk/Wht). Which is why you always see your dash, stereo, and such, flash off when you 'start' the car. Basically it disconnects accessory and systems power during a start cycle. I'd assume to conserve amp draw.
If you have any other questions, PM me.
Old 09-29-2004, 04:37 AM
Paragraph Alert
ActiveAero's Avatar
Default Re: Ignition switch wiring question. Please help. (project_mercy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project_mercy &raquo;</TD></TR><TR><TD CLASS="quote">functionally, here's how it works.
If you have any other questions, PM me.</TD></TR></TABLE>
x10000000
I'll PM you if I have trouble rigging something up.
Old 09-29-2004, 12:56 PM
as per my PM
The reason for the two SPST's is, I didn't feel like switching all that power through a single relay. I'm not sure what amperage draw is between those two lines. You're welcome to drop it to one if you want.
Make sure they're at least 30amp relays.
Old 09-29-2004, 01:07 PM
nocturnaldragon's Avatar
You could allways goto the junk yard and get a new switch, i belive the modual part on the back can be removed and switched to your old key cylinder without much work but dont hold me to that, far less then $250
Old 09-30-2004, 06:53 AM
JinDIESEL's Avatar
hope u fix your prob, man
Old 10-10-2004, 09:28 PM
jasperl33
Guest
Posts: n/a
Default Re: Ignition switch wiring question. Please help. (nocternaldragon)
Do you know if I can put the ignition switch from a 2001 integra into a 2000 civic LX. Will that be compatible?
Old 10-10-2004, 10:48 PM
jasperl33
Guest
Posts: n/a
I have a 2000 civc LX and bought a 2001 gsr. The problem is gsr eci has the immobilizer and there is a way to remove it but it will keep the engine light on. Somone told me to get a gsr ignition switch and put it in the civic and have the acura dealer to reprogram it. My question is will the gsr ignition switch fit into the civic or do I need some modification. Need your help. thanks
Old 10-10-2004, 10:54 PM
Br1anPham's Avatar
Default Re: Ignition switch wiring question. Please help. (jasperl33)
saved for future reference.
spoolin-4
11-15-2011 06:10 PM
Ryan559
10-06-2010 08:41 PM
Honda Crx
Audio / Security / Video
16
06-05-2007 07:35 AM
Un0Turb0-WP
10-19-2004 11:45 AM
Ausmith
01-15-2003 10:55 AM
Quick Reply: Ignition switch wiring question. Please help.
