ignition output signal CEL #15 - Honda-Tech
Old 11-06-2008, 04:43 PM   #1
obuhmyuh's Avatar
Default ignition output signal CEL #15
hey guys i had a code 9 the other day CYP sensor (cyl 1 sensor), so i bought and installed a new dizzy from AZ and i was driving home and my car just shut off and a code 15 popped up. I think there may be a wiring problem near my ecu, so i checked those wires out and fixed a couple.
Cliff notes:
95 del sol si (jdm sohc vtec JDMd15b obd1)
car wont start (but will everyonce in a while when i tinker with the wires but shuts off
CEL #15 ignition output signal
anyone have some expertise?
obuhmyuh is offline   Reply With Quote
Old 11-07-2008, 02:19 PM   #2
obuhmyuh's Avatar
Default Re: ignition output signal CEL #15 (obuhmyuh)
bump
Old 11-07-2008, 02:31 PM   #3
Here's where to concentrate:
1) The igniter may be bad.
2) The Yel/Grn wire between the igniter and ECU may be bad (open or short).
3) The Blk/Yel wire between distributor 2P connector and ignition switch may be bad. There should be battery voltage with the key turned to ON(II).
Former User is offline   Reply With Quote
Old 11-07-2008, 02:34 PM   #4
obuhmyuh's Avatar
Default Re: ignition output signal CEL #15 (RonJ@HT)
yeah all of my wires are hacked to bits around that area by my ECU. I tried using a different ECU as well...
sounds like im going to need a mutimeter, i checked for power at the yellow/green wire using a lightbulb and ground and it looks like theres power there (maybe insufficient though???), i literally had just replaced the dizzy when this **** happened and i was driving away from autozone, so im not thinkin its the dizzy too much since its new...
Old 11-08-2008, 02:06 AM   #5
obuhmyuh's Avatar
ttt
Old 11-09-2008, 08:45 AM   #6
obuhmyuh's Avatar
bumppp
Old 11-09-2008, 05:54 PM   #7
LS94tegra's Avatar
hey did you ever figure this out? my buddy has the same problem but he has no spark, and throwing code 15.
LS94tegra is offline   Reply With Quote
Old 11-10-2008, 12:46 AM   #8
obuhmyuh's Avatar
Default Re: ignition output signal CEL #15 (LS94tegra)
not yet, could use some help though...
Old 07-16-2009, 04:31 PM   #9
moknoy's Avatar
I am having this problem now with my civic. Necro but answers will be great!
moknoy is offline   Reply With Quote
Old 07-30-2009, 10:28 PM   #10
hialeahzbg's Avatar
i have the same problem....ive changed the dizzy and ecu and still...im getting no spark...
hialeahzbg is offline   Reply With Quote
Old 07-30-2009, 10:35 PM   #11
Quote:
Is the CEL on?
Does the Blk/Yel wire in the distributor have battery voltage with the key in ON(II)?
Does the Yel/Grn wire running between the igniter unit and ECU have continuity? What voltage does this wire have at the igniter unit with the key in ON(II)?
Old 07-31-2009, 10:11 AM   #12
hialeahzbg's Avatar
Quote:
Originally Posted by RonJ@HT View Post
Is the CEL on?
the cars at a friends house and hes working on it but he hasnt been about to figure anything out...ima text him what u wrote...what if the blk/yel wire in the dizzy has voltage?
Old 07-31-2009, 10:18 AM   #13
hialeahzbg's Avatar
ok he said it does not have power...
Old 07-31-2009, 10:25 AM   #14
No power with the key in ON(II), right?
If so, the Blk/Yel wire is broken somewhere between the distributor connector and the ignition switch OR the ignition switch is bad. Have him check those two possibilities.
Old 07-31-2009, 11:40 AM   #15
hialeahzbg's Avatar
AwEsome... I'll have him look at it.. Anything else it could be?
Old 07-31-2009, 11:46 AM   #16
What year? Did he already inspect the Blk/Yel wire pins in the distributor connectors for damage? Does the windshield washer motor work?
Old 07-31-2009, 12:34 PM   #17
hialeahzbg's Avatar
It's a 95 rhd sir eg6
Old 07-31-2009, 12:39 PM   #18
Okay. Any answers for the other two questions?
Old 07-31-2009, 12:42 PM   #19
hialeahzbg's Avatar
He's gonna get home like 3 hours... I texted him wat u wrote...
Old 07-31-2009, 12:43 PM   #20
hialeahzbg's Avatar
Can u pm me ur number so we can call u?
Old 08-01-2009, 10:52 PM   #21
hialeahzbg's Avatar
Thanks!!! it fixed my problem!!!
Old 08-01-2009, 11:04 PM   #22
Great. What was the solution?
Old 08-03-2009, 07:49 AM   #23
hialeahzbg's Avatar
bly/ylw was ripped somewhere between the ecu plugs...
Old 12-28-2009, 11:37 AM   #24
eaddagwan's Avatar
good stuff, im having the same issue here, hopefully i can see about just replacing the black/yellow wire all the way through. any advise going into it?
eaddagwan is offline   Reply With Quote
Old 06-30-2010, 11:12 AM   #25
hey i have the same problem...ive checked the blk/ylw wire and it has a current but am not sure how to test the igniter
killa94 is offline   Reply With Quote
Ignition output signal missing CEL 15 Frany Acura Integra 2 01-30-2016 05:25 PM
95 Civic Ex - shaky acceleration, low idle, 3 CEL codes JCORTES Honda Civic / Del Sol (1992 - 2000) 17 10-28-2013 09:06 AM
94 integra cel code 15 Ignition Output Signal HELP greyejcoupe Acura Integra 0 08-01-2008 04:31 PM
Cel 13 and 15 Question EfSedanLove Honda CRX / EF Civic (1988 - 1991) 0 02-02-2007 05:56 AM
Code 15: Ignition Output Signal Brett420 Tech / Misc 1 10-08-2004 03:36 PM
Tags
15, 88, 94, accord, acura, cel, civic, code, crx, honda, ignition, ignitor, integra, output, si, signal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
