Ignition Fuse Keeps Blowing Out
Old 05-13-2010, 07:06 AM
azandford's Avatar
Default Ignition Fuse Keeps Blowing Out
Car wouldnt start so i did all the normal things....tried a jump and then i bought a battery...didnt work. I checked the under hood fuses and noticed the ignition fuse was blown. i went and bought a new one. As soon as i turned the key to the on position i had some hope but as soon as i tried to start it it blew the fuse.
i tried it 4 more times. Every time the fuse blew right as i tried to turn it on. I have no idea what to do next. Please help!
Old 05-13-2010, 07:41 AM
azandford's Avatar
Default Re: Ignition Fuse Keeps Blowing Out
bump cuz im stuck at advanced auto parts
Old 05-13-2010, 08:03 AM
Former User's Avatar
Does the fuse blow when the key is turned to ON(I)/ACC or ON(II) or only when turned to ON(III)/START?
Old 05-13-2010, 08:06 AM
azandford's Avatar
only when you turn it to start
Old 05-13-2010, 08:09 AM
Disconnect both starter wires to see whether this prevents the fuse from blowing.
Old 05-13-2010, 08:11 AM
azandford's Avatar
well im gonna have to buy some more fuses..lol
ok if it doesnt blow if then is it wiring to the starter or a starter issue? the starter is brand new
Old 05-13-2010, 08:19 AM
If the fuse does not blow with the starter disconnected, then there's a short in the starter and it needs to be replaced.
If the fuse still blows with the starter disconnected, then the short is in the ignition switch or the wires between the ignition switch and starter.
Old 05-13-2010, 10:25 AM
azandford's Avatar
so i unplugged the wires and tried to start it and it did not blow the fuse
does this mean it is the starter at fault?
Old 05-13-2010, 10:47 AM
Yes, there's a short inside the new starter.
Old 05-13-2010, 11:43 AM
azandford's Avatar
Thanks for the help. Ill update you when I get the starter tomorrow and hook it up
Old 07-01-2017, 05:39 PM
Babayaga94's Avatar
I have a 1995 Honda accord ex v6 Ignition fuse keeps blowing dont know why and its getting really annoying.. Has alarm with push start. I try to start it with beeper and it trys to start but doesnt so i try to start it with key and as i turn the key fuse blows n everythime i change it. It keeps blowing... Please Help Me
Mason Edmison
10-22-2017 09:19 AM
RPMvulocity
08-12-2010 02:51 PM
teler86
10-24-2006 06:10 AM
ILIKEJDMX999
04-19-2006 06:33 AM
zhan28
03-08-2006 04:54 PM
Quick Reply: Ignition Fuse Keeps Blowing Out
