Idle Probs. with D15B Vtec, O2 Sensor Wiring ??
Old 04-11-2005, 11:21 AM
exploder101's Avatar
Default Idle Probs. with D15B Vtec, O2 Sensor Wiring ??
Car Info:
93 DX Auto
D15B Vtec
DX Tranny
P08 Ecu
Well ever since my motor was installed ive been having all sorts of idle problems. At around January (Chicago winter) whenever temps would drop to below zero, my car would be constantly reving up and down until the motor was warm. No CEL ever came about. I fix that problem by removing my FITV and tightening that screw inside the sensor. However, whenever I would park my car(having it on P, its an auto ) I could hear and feel the idle moving move up and down again. No CEL ever showed.
I tried replacing and cleaning the IACV, but it didn't really help much. Problem still exists today, with warm temps outside. Im also noticing that whenever my car is in motion and when I step on the break, and when my RPM drops to 1000, the car jolts and the tach reading rises again, then finally drops down close to 100 RPM, where the car then starts to shake at a stop. NO CEL again.
BTW, the CEL works, I was getting code 22, replaced the sensor and that rid the code.
I did some more research and discovered a faulty O2 sensor might be the problem. So anyways I found out that the P08 Ecu reads a 1 wire O2 sensor, and upon inspection of my car's wiring I saw that I was using a 4 wire O2 sensor. And this is where im stuck. I tried searching but couldn't find any topics on coverting 4 to 1 wire, and what wire I would need to run to the ECU, if any at all. Please help rid of this annoying problem!!!
Old 04-11-2005, 11:28 AM
Slammd Sol's Avatar
Is your P08 ecu for an auto engine?
Old 04-11-2005, 11:29 AM
Default Re: (Slammd Sol)
Yea the P08 is auto.
Old 04-11-2005, 03:15 PM
Default Re: (exploder101)
Bump becuase im now throwing Code 22 and 17, Vtec pressure Valve and VSS. Don't know if this is related to the idle problem though.
Old 04-11-2005, 04:06 PM
no more codes, but idle still exists.
Old 04-24-2005, 07:46 PM
urquidezj's Avatar
check the plugs that go to the back of the intake manifold on the driver side. i have one left out, i dont remember the color of wires for the plug of my head but if u switch it, that will go away, worked on my moms 95 ex civic. pm me so i can tell you the colors.
Old 04-24-2005, 07:55 PM
ihateslowhondas's Avatar
did you change the throttle body?
Old 04-24-2005, 08:36 PM
EG_FTW's Avatar
i had the same problem with my d15 there is a small opening on the front of the manifold next to the trottle body it has two small screws and the opening is circular there is a threaded piece of plastic crap there make sure it is all the way screwed in thats how my crap was solved good luck
Slacker93eg
04-27-2013 08:46 AM
so simple
10-16-2009 01:43 PM
reed857
29
07-26-2009 10:57 AM
punkracer
02-01-2009 06:57 PM
pyromaster
04-07-2005 11:03 AM
Quick Reply: Idle Probs. with D15B Vtec, O2 Sensor Wiring ??
