idle issue! yes i searched!
Old 12-01-2012, 10:26 PM
dc4b20's Avatar
Default idle issue! yes i searched!
engine is a d15b7. i just purchased the car and im fixing its problems. had a searching idle. i replaced the iacv and that fixed the searching idle. now the car idles around 2k when cold and at 1500 when it warms up. i checked the tps and its good. removed the ficv, cleaned it, adjusted it, and still the high idle. ive bleed the cooling system also. im running out of ideas of how to get this idle down. help!!!! i need to get this car smogged.
Old 12-01-2012, 10:29 PM
jbpnoman's Avatar
Default Re: idle issue! yes i searched!
Follow FSM procedure for adjusting your idle speed. You should be able to find a write-up in the FAQs sticky. Alternatively, get your hands on a FSM for your car. They're invaluable.
Old 12-01-2012, 10:44 PM
dc4b20's Avatar
ill try that procedure tomorrow. any other ideas?
Old 12-02-2012, 08:22 AM
Technical Hero
HondaPartsHero's Avatar
Try that first. More than likely the previous owner had the idle problem and attempted to fix it with the idle screw and or hopefully not the base idle screw.
Old 12-02-2012, 11:17 AM
Hondaguy83's Avatar
Check for leaks again around the USC gasket and make sure hoses goes where it belongs. Could be another bad iac.
Old 12-02-2012, 12:57 PM
dc4b20's Avatar
Where is the "base idle screw"? The iacv was changed and fixed the up and down idle.
Old 12-02-2012, 01:26 PM
Technical Hero
Sorry should be called throttle stop screw. This should never be messed with, you can tell if someone did if the paint from the factory put on it is broken or looks adjusted.
Old 12-02-2012, 02:13 PM
dc4b20's Avatar
So.....my throttle stop screw has been adjusted. There is a small gap between the gap screw and the throttle plate. And the yellow paint has been broken. Where do I go from here to get that idle down?
Old 12-02-2012, 02:58 PM
Technical Hero
If you can tell where the original paint stopped and started you can try to turn it back. I'd still try to do the factory idle adjust first and make sure that its right first.
Old 12-02-2012, 05:41 PM
Hondaguy83's Avatar
I bet u got a slight vacuum leak or stuck open idle air control. Try cleaning by spraying cleaner in throttle body and hope it clears out the iac. Reset ecu if its obd2. See what happens.
Old 12-02-2012, 06:13 PM
dc4b20's Avatar
Thanks for the help. I already checked for vacuum leaks, but I will re check that tomorrow and set it to the factory idle and see what happens. What should happen if I put my finger and cover the holes inside the throttle body? One at a time of course.
Old 12-02-2012, 10:36 PM
Hondaguy83's Avatar
Car wil die. Don't do that. Sometimes u just gotta double check things twice or you'll be looking forever. Spray around gaskets and check for leaks around pcv valve but recommend changing it because if its stuck open it will cause that.
Old 12-03-2012, 12:10 AM
dc4b20's Avatar
Pcv valve will cause it to idle high? Is there any way to check it, or do I just have to replace it?
Old 12-03-2012, 12:30 AM
Hondaguy83's Avatar
Pinch off the hose n see if idle goes down. Should be a slight drop or take the valve out and plug with finger. It might idle lower than specs but gives you an idea.
Old 12-03-2012, 08:51 AM
dc4b20's Avatar
Ok thanks. I'll try that today.
Old 12-03-2012, 12:51 PM
Hondaguy83's Avatar
What I've learned from smog school is normal it should drop 50rpms if more than that ilu know the valve is no good and allowing more air than before
Old 12-03-2012, 01:08 PM
dc4b20's Avatar
ok, i took off the valve and plugged it with my finger and the idle seemed to drop a little bit. noticeable by ear. is that normal? i also tried to set it to the factory idle adjustment as well and that did not work. if i unplug the iacv sensor, it seems to idle alot lower. is this normal?
Old 12-03-2012, 04:07 PM
moejoepotatoe's Avatar
You should be adjusting the base idle ith the IACV unplugged and with the service connector jumped, well at lease that's how you do it on my b16a. Find the write up and you'll know for sure how to do it.
Old 12-03-2012, 05:31 PM
dc4b20's Avatar
I tried searching "adjusting base idle" and found nothing.
Old 12-03-2012, 06:21 PM
Hondaguy83's Avatar
Plan b.take off your intake arm and clean out your throttle body with throttle cleaner spray and hopefully it will clean out your iac too when the spray goes into the iac hole In Your throttle body.
Rev it up alittle while applying spray. See if that clears out and work.
If that don't work try this.
2. Test your coolant temp sensor if your car is obd2 u can use a scanner and read voltage and temperature. If obd1 u can try another method by finding resistance specs and calculating what temp and resistance it suppose to be at. Also check the voltage.
Old 12-03-2012, 08:37 PM
jbpnoman's Avatar
Remember that part where I said "Get the factory service manual for your car, and follow the instuctions"? The FSM has a very comprehensive, easy to follow write-up on adjusting idle.
Old 12-03-2012, 09:50 PM
dc4b20's Avatar
I don't really want to buy a service manual for this engine cause its gonna be swapped out before next summer.
Old 12-03-2012, 09:54 PM
jbpnoman's Avatar
I never said buy, I said obtain. Borrow, rent, download, there are plenty of cheap/free methods that don't involve paying full price for a brand new one.
minner
10-08-2006 01:30 PM
DC2*Integra
09-20-2005 12:51 PM
Civic Racer X 7
07-23-2003 07:19 AM
Pele
02-09-2003 01:01 AM
Quick Reply: idle issue! yes i searched!
