I need help removing trim on the rear hatch....
Anyone have a DIY or a link to help me remove the trim on the rear hatch of my hatchback? I'm trying to wire a rear view camera and need to pop the panels off and wire it.
H-T White Ops
Two clips at the bottom under the latch. Apparently you're supposed to press the middles in while you pull the outer section out. I managed to just pull though and broke both of mine. $2.59 apiece to go spend at Honda.
The rest on that inner panel are clips behind the panel. Pull the entire panel away to remove those clips.
By the way, if anyone can help me to figure out how to completely remove the last grey clip (shown in this pic) that is stuck in the car, that would be very helpful. The section of the clip sticking out is very flexible and my clip puller just lets it slip out. The other side, while difficult to get to with pliers, is much tougher and i can't pinch it enough to remove.
Here are all the clip locations to help anyone else though.
VX
32
04-11-2013 05:27 PM
acmoc
04-05-2010 09:21 AM
