Hydraulic Clutch adjustment...:? - Honda-Tech
Old 11-10-2005, 10:38 PM   #1
redsikiller's Avatar
Default Hydraulic Clutch adjustment...:?
I remember a few years back, I heard some kids who worked at the dealership say a hydraulic clutch adjusts itself.
I just put the clutch pedal from a b18 integra into my d-series civic, I have an exedy stg 1 clutch, and nothing to judge it against, especially since the service manual didn't intend for a stage 1 clutch. How do I tune this pedal for my car and clutch?
redsikiller is offline   Reply With Quote
Old 11-10-2005, 11:25 PM   #2
slo97coupe's Avatar
Default Re: Hydraulic Clutch adjustment...:? (redsikiller)
slo97coupe is offline   Reply With Quote
Old 11-10-2005, 11:43 PM   #3
civic_driver's Avatar
i'm assuming everything fits... if it does, you tune it from the clutch master cylinder under the dash...
unscrew 12mm nut, tilt the rod that goes in the clutch master clockwise to increase freeplay and counter clockwise to decrease it (if i remember correctly)
civic_driver is offline   Reply With Quote
Old 11-11-2005, 01:57 AM   #4
lv6l's Avatar
yeah, turn the stud stick thing that is connected to the bushing that goes out to the master cylinder. turn it until you see your pedel dropping or raising to the height you want. and make sure you adjust the 2nd stud. located further back and up, its a 14mm and it holds the clutch pedal down or up for adjusting freeplay. do this correct, i know a lot of people that adjust just one and they burn their clutch or ride the heck outta it. MUST ADJUST BOTH STUD CORRECTLY
lv6l is offline   Reply With Quote
Old 11-12-2005, 02:37 PM   #5
Default Re: (lv6l)
thanks guys, exactly what I needed to know.
Old 11-18-2005, 01:29 PM   #6
slo97coupe's Avatar
any more info or pics or diagrams???
Old 12-02-2005, 09:52 AM   #7
Default Re: (ek97-DAP)
How do you know what the right position is though, for an aftermarket clutch. When I shift quick, my 2nd gear grinds a little, but is that typical for 92 civics?
Old 12-02-2005, 09:58 AM   #8
nocturnaldragon's Avatar
Default Re: (civic_driver)
You do remember correctly.
nocturnaldragon is offline   Reply With Quote
clutch grabs at top of pedal 76 camaro car Honda Accord (1990 - 2002) 3 09-18-2016 02:45 AM
can a hydraulic clutch be adjusted? 76 camaro car Honda Accord (1990 - 2002) 6 01-18-2016 06:29 AM
need help adjusting stiffness in my clutch allshownogo Honda Civic / Del Sol (1992 - 2000) 4 06-25-2008 01:06 AM
Possible to Adjust the Hydraulic Clutch on a 94 Civic Ex madhatter07 Honda Civic / Del Sol (1992 - 2000) 7 01-06-2006 04:05 PM
Adjusting the clutch sshaikh01 Acura Integra 6 09-28-2002 08:17 PM
Tags
08, adjustable, adjustment, civic, clutch, cons, d16y7, del, honda, hyd, hydraulic, hydraulics, hydrolic, sol, tech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
