HX 5 wire o2 sensor help
Old 05-20-2012, 10:24 AM
TheMechanic84's Avatar
Default HX 5 wire o2 sensor help
does anyone have a wireing guide for the 5 wire o2 sensor to ecu? the plug is 7 wires and the o2 sensor is 5 and i have no idea how to wire it up....any help would be greatly appreciated.
i need to know what color wire from the o2 sensor connects to the 7 wire plug followed by its color..
yes ive searched but only seem to find 4 wire diagrams
Old 05-20-2012, 11:30 AM
Technical Hero
HondaPartsHero's Avatar
Default Re: HX 5 wire o2 sensor help
What exactly are you trying to do? Setup wise?
Old 05-20-2012, 01:37 PM
i have a 5 wire o2 sensor, but the plug was cut off so now im trying to hard wire it into the harness so i can pass emissions, buying a 300+ dollar o2 sensor for a car im not keeping is out of the question.
maybe this will help
the colors on my o2 are orange, green, black, red, and white.
the color on my plug is thick black, thick white, thick red, white, green, solid black, and black with white strip.
Old 05-20-2012, 01:40 PM
the code im geting is a p1166 primary heater system electrical...my scanner blinks o2s, cat, and EGR...
side note i hate obd2
Old 05-20-2012, 02:04 PM
https://honda-tech.com/forums/showth...2973436&page=2
this link kind of gives me some info on the ones i need to ignore.
Old 05-20-2012, 02:22 PM
LOL I know someone has to have the same sensor as me...just take a picture of your harness clip showing the wires on both ends, especially if there the same colors as my o2 sensor.
DO IT!!! lol
Old 05-20-2012, 02:48 PM
Technical Hero
https://honda-tech.com/forums/showth...2+hx&t=2145030
Old 05-20-2012, 02:56 PM
Originally Posted by HondaPartsHero
Your awesome! Cyber high Five!!
Old 05-20-2012, 03:14 PM
beecee18's Avatar
Its not fair to hate something above you, learn it, conform, the scanner blinks the 02, cat, egr.
Its doing this cause these are readyness monitors that have not ran there course and passed yet. the more driving you do, the chance of them blinking will stop unless there is a fault. If you havent reset the ECU recently those monitors havent passed because it reconizes a fault, and a check engine light is in your near future.
You would love OBD2 if you simply learned it as the data on that scantool tells you whats wrong with your car, and you wouldnt be here asking us.
Dont be scared to learn, you might find it interesting.
Old 05-20-2012, 07:13 PM
i dont hate obd2 just because its obd2...i hate it because its hard to upgrade and keep it from throwing a code. ive been working on hondas for awhile...mainly up to 95 because of how it easy it is work with and you dont have to plug it into a computer in order to pass inspection.
ok so i wired up my O2 and now i get a p1169 High voltage input or something..i do have a crack in my header but thats no even on the same pipe as the o2 sensor is on, and i am burning a considerably large amount of oil at around 5k+ RPM's.
any info about the p1169 check engine?
Old 05-20-2012, 07:19 PM
beecee18's Avatar
-LAF connector is damaged (check pins for damage, and for moisture)
-LAF sensor signal circuit is shorted to voltage
-LAF sensor has failed (it may be contaminated with fuel, silicone or water)
-PCM has failed
what this means is your wiring is still off probably
or it could be the crack in you manifold and it doesnt matter that it is not near the 02.
your probably not getting the fuel economy you should out of this car either.
Garzachr000
11-24-2014 05:52 PM
accord2civic2prelude
10-11-2010 07:29 PM
turbotime
12-06-2006 06:40 AM
trooper0641
04-28-2004 08:31 AM
Quick Reply: HX 5 wire o2 sensor help
