humming sound coming out from cam gear - Honda-Tech
Old 04-07-2008, 11:24 AM   #1
civic_tuned's Avatar
Default humming sound coming out from cam gear
Recently the head was repaired i had a blown head gasket. Car not heating up or anything. I still feel hoses hard until thermostat opens..which is usually when fans turn on.
After work was done i noticed humming sound coming from timing belt area. I took of the t. cover to hear better where sound was coming from. I noticed the noise was coming from the cam gear. I checked my timing belt and feels kinda tight. Kept on checking and im hearing wierd thunt noise also but dont know if its the water pump or tensioner.
Water pump is a year old as well as the tensioner.
civic_tuned is offline   Reply With Quote
Old 04-07-2008, 11:44 AM   #2
Jim Truett's Avatar
Default Re: humming sound coming out from cam gear (civic_tuned)
Quote:
Fix that first....
Jim Truett is offline   Reply With Quote
Old 04-07-2008, 12:06 PM   #3
blk92_d16's Avatar
Define tight? Like you can't flex the belt at all? It can have up to 3/4ths an inch of deflection. If it's too tight, it can cause premature bearing failure in the water pump and such...
blk92_d16 is offline   Reply With Quote
Old 04-08-2008, 07:14 AM   #4
Default Re: (blk92_d16)
Quote:
maybe your right...**** i didnt know water pumps had bearings.
Good to know!
how about the cam?
Old 04-08-2008, 06:03 PM   #5
Default Re: (civic_tuned)
how about the cam gear?
or is it too tight whats causing hte problem?
Humming noise lit549 Honda Accord (1990 - 2002) 16 08-26-2015 02:29 PM
Civic timing/Water pump Replacement noises BIGef Honda CRX / EF Civic (1988 - 1991) 6 09-07-2012 11:02 AM
Bad bearing noise coming from D16y8 freshgear Honda Civic / Del Sol (1992 - 2000) 7 07-07-2012 04:53 PM
whining noise after complete tb change Inextricabledrvr Honda Prelude 5 05-20-2009 12:07 PM
loud humming noise coming from engine bay? Ibuprofen Acura Integra Type-R 7 01-10-2002 04:51 AM
Tags
bearings, camshaft, gear, humming, tight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
