How to undo adjustment to throttle plate stop screw. - Honda-Tech
Old 05-09-2009, 06:26 PM   #1
dth0ng69's Avatar
Default How to undo adjustment to throttle plate stop screw.
I have a d16y7. Alright so my friend, in attempt of fixing my low idle accidently adjusted the throttle plate stop screw. which is in that area
http://img.photobucket.com/albums/v2...estopplate.jpg
its the one where you adjust the nut and use a hex set to turn the screw.
I've been told by some HT members that you should never touch that part, because it effects the TPS output, and round out a bore and cause a perma-vac leak.
So I want/need to change it back to the way it is suppose to be, I got a explantion from a HT member, I just want to clarify if its correct. thnx.
this is what he said
"the throttlebody "Stop screw" adjustment is simple. You want the throttle body to be as closed as possible without sticking. usually you can back the screw out till it doesn''t touch, Snap the throttle closed so it sticks and slowly turn the stop screw in till you hear the butterfly "pop" open.. lock the screw and test operation to make sure it doesn't stick after being snapped shut.. your TPS voltage should read .45-.50v on the signal wire."
THNX for reading... any suggestions?
dth0ng69 is offline   Reply With Quote
Old 05-09-2009, 06:47 PM   #2
civic_driver's Avatar
Default Re: How to undo adjustment to throttle plate stop screw.
You can adjust it if it sticks or if air gets in without you pushing the gas pedal.
And here is your picture:
civic_driver is offline   Reply With Quote
Popping Noise from steering wheel/column when turning side to side dth0ng69 Honda Civic / Del Sol (1992 - 2000) 1 05-03-2016 10:54 AM
Removing IAC valve D16y7?? dth0ng69 Honda Civic / Del Sol (1992 - 2000) 12 08-19-2009 05:12 PM
how is Fram? dth0ng69 Honda Civic / Del Sol (1992 - 2000) 14 08-15-2009 04:57 PM
Weird Idle Problem dth0ng69 Honda Civic / Del Sol (1992 - 2000) 0 07-28-2009 09:39 PM
is it bad to adjust the throttle stop screw??? _Endless_ Tech / Misc 2 02-13-2004 10:58 AM
Tags
acura, adjust, adjustment, choke, civic, honda, integra, located, plate, prelude, sale, screw, stop, throttle, trottle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
