how to test oil pump?
Old 05-31-2009, 05:22 PM
coryfenton's Avatar
Default how to test oil pump?
Hey i think my oil pump may be dying on my b16...
is there any test to see if that is it?
or how to tell if there bad..
any help is appreciatted thanks..
Old 05-31-2009, 05:25 PM
Former User's Avatar
Default Re: how to test oil pump?
Connect an oil pressure gauge where the oil pressure switch is to measure the fuel pressure.
Old 05-31-2009, 05:34 PM
coryfenton's Avatar
What should it be at? If it was going out would my oil light in instrument cluster be on?
Old 05-31-2009, 05:37 PM
civic_driver's Avatar
If the oil pressure is too low the light should light up.
At idle oil pressure should be 10psi and at 3000 rpm the pressure should be 50psi.
Old 05-31-2009, 05:45 PM
coryfenton's Avatar
so if the oil pump was dying would the light be on at idle?
Old 05-31-2009, 05:51 PM
Yes, assuming that the oil pressure switch and light work.
Old 05-31-2009, 11:05 PM
coryfenton's Avatar
they do, I have a brand new oil pressure sensor/switch. and the lights work..
Old 06-01-2009, 12:29 AM
waaBAAH's Avatar
if your oil light is on and you replaced the sensor already you still could be looking at more things beside the oil pump...
could be somethign simple like your oil filter is clogged or the wrong oil filter or even wrong oil resulting in a restriction of your oil flow.
another idea that i hear tossed around but wonder myself about (will explain why shortly) is bad bearings. the theory is your bad bearings will make your oil channels bigger whcih would screw with the pressure. think garden hose style for a moment...if you put your finger over the end it will create more pressure....if you take your finger off the end it will lessen the pressure.
now what i dont agree (or understand for that matter) is the oil still should be read at the filter area way before it reaches the end path of yoru bearings. the filter area (with bad bearings) still should be 10 psi where the bearing area might be 2 psi on the bearings. how can the sensor read this 2 psi since it is at the end?
im just rambling...do an oil change and make sure you have the rght filter installed and such.
Old 06-01-2009, 05:58 AM
Kista20's Avatar
you have checked the oil? I know when mine is low the light will come on every so often.
Schultzie
07-10-2010 08:58 PM
Retribution
04-01-2009 06:22 PM
lonewsome
01-01-2009 01:42 PM
eric416
10-09-2008 04:03 PM
xlee08
10
04-01-2008 02:00 PM
Quick Reply: how to test oil pump?
