How to tell Fuel Injector sizes
Old 05-06-2009, 02:51 PM
raidacaipo's Avatar
Default How to tell Fuel Injector sizes
How can you tell the size of a honda injector just by looking at it? I know you can tell whether they are peak and hold injectors just by measuring the volts/ohms but how can you tell the size of the injectors?
As you all know that most B series injectors will be 235cc whereas the H series is 345cc.
My Jdm h22a injectors says 5KJD on them as well as Japan KEI HIN. What does 5KJD mean?
I also compared 2 injectors and took off the filter to see the hole on the inside where the fuel goes into. On 1 of the injector, the hole is bigger than the other one. Can you tell the CC sizes just by comparing the two hole sizes?
Old 05-06-2009, 03:30 PM
raidacaipo's Avatar
Default Re: How to tell Fuel Injector sizes
bump
Old 05-06-2009, 03:40 PM
iwanttokillgod's Avatar
not all h series are 345cc
Old 05-06-2009, 05:06 PM
raidacaipo's Avatar
well Jdm 92-95 h22a injectors are....
Old 05-06-2009, 05:25 PM
that is correct and they are green tips only ones that came that way
Old 05-06-2009, 08:49 PM
raidacaipo's Avatar
only jdm h22 injectors come with dark green tips? because I bought from a friend some h22 injectors with green tips.. I just wanted to make sure. I just hope they are 345cc and not 235cc which may be too lean for my motor.
thirsk66
06-24-2014 10:00 AM
rayray24
11-08-2012 06:20 AM
si90rex
09-08-2006 05:33 AM
GOLDBERG
10-20-2002 06:51 AM
Quick Reply: How to tell Fuel Injector sizes
