How to reset/turn off engine light
I own a 94 honda civic ex coupe.. im new to this civic but im not a noob when it comes to integra .. my engine light is on and im just wondering how to turn it off? is ther a button that u can use to turn it off? thx in advance
oh btw this is the car
Re: How to reset/turn off engine light
Remove the under-hood 7.5A Back Up fuse for about one minute and then reinsert. This will clear the ECU.
However, if the fault that caused the CEL code still exists, then the CEL will turn ON again the next time you turn the key to ON(II), run the engine, or drive the car.
Click here to learn how to pull the CEL codes.
ok so i just used a paper clip and i getting 4 quick/short flashes.. i think thats a crank position sensor.. can anyone correct me if im wrong?
Actually, on 96-00 civics, you have to take out the backup fuse for longer than one minute. I took my backup fuse for a few minutes and the ECU didn't reset. Then I took it out for 10 minutes, and it reset.
Edit: Never mind, that's a 94 civic.
just for my sake, can you just unhook the negative battery terminal for a little while? that's how i have been doing it, and it seems to work just fine?
unless your like me, i have my negative terminal real loose because i have to unhook it often because my alarm sets itself, making working on my car or even cleaning it. haha but, i realized i can just open a door and it works the same, i suppose i could tighten it by this point. but, i'll stop getting off topic with this one. haha
That's a bad idea. The connection has to be good (i.e. you have to tighten up the connector to the negative terminal) if you don't want any electrical problems.
joey_B
12-23-2015 05:47 PM
