Can I still use my crank shaft gear? It has 3 slightly damaged teeth.
Old 09-18-2004, 04:27 PM
Calvinator's Avatar
Default Can I still use my crank shaft gear? It has 3 slightly damaged teeth.
The crank shaft gear that I have on my y8 ( gear that connects to to timing belt) has 3 teeth that have been damged. They are slightly grinded down. It appeared that they would still work, but I just wanted to know if this will harm anything or cause any future problems?
Old 09-18-2004, 04:51 PM
ABK
ABK's Avatar
Default Re: Can I still use my crank shaft gear? It has 3 slightly damaged teeth. (xtremeazian)
you could rip the timing belt, you prolly will.
Old 09-18-2004, 05:05 PM
Kamin's Avatar
do you really want to take that chance? i mean it drives your timing belt....
Old 09-18-2004, 05:09 PM
Calvinator's Avatar
ok thanks, I'm just going to replace it.
Buffalo.Rider
01-24-2020 03:02 AM
boostedteg4dr
02-25-2014 08:39 PM
j4s0n1337
02-15-2012 03:07 PM
mymeatb18"
11-02-2006 08:55 AM
H22AJSPEC
07-16-2003 07:38 PM
Quick Reply: Can I still use my crank shaft gear? It has 3 slightly damaged teeth.
