How to remove steering wheel???
Old 12-02-2003, 03:23 PM
93EH6
Guest
Posts: n/a
Default How to remove steering wheel???
Does any one know how to take off the steering wheel in a civic or del sol???
Old 12-02-2003, 03:32 PM
ExiledinIN's Avatar
Default Re: How to remove steering wheel??? (93EH6)
https://honda-tech.com/zerothread?id=286910
Pretty much as it says. Make sure you take all necessary precautions (pull off neg. and pos on battery, hook the red short connector, etc.) on the airbag. I was a little more insane. I took a belt and hooked it around the steering whell until I got the torx screws out (just in case).
How do I get this connector off??? For some reason I'm not able to pull it out.
Old 12-02-2003, 03:37 PM
GsR HtCh's Avatar
Default Re: How to remove steering wheel??? (ExiledinIN)
if thats the same one you need to take off for the fog lights than it takes a little time to get it off. it took me like 20 minutes of pulling to get mine off
Old 12-02-2003, 03:43 PM
ExiledinIN's Avatar
Default Re: How to remove steering wheel??? (GsR HtCh)
that connector goes to the cruise accel/decel switch.
Old 12-02-2003, 05:10 PM
shauniewalnuts's Avatar
ok i just replaced mine so here goes...
unscrew the screw on the ignition cover
then undo the bolt on the wheel i and pretty sure they have a star pattern
then the airbag will come out next undo the bolt in the center i think its a bitch getting off
after you get the bolt off and disconnected the wire you gotta pull the wheel off...
its not going to come off easily you have to get a nice grip and it and pull that son of a bitch as hard as you can (it took me and my friends about 5 yanks at the same time to get it) but then it comes right off
reverse procedure to put it back on! Hope this helps
*****EDIT: DISCONNECT THE NEGATIVE TERMINAL ON THE BATTERY FIRST!!****
Old 12-02-2003, 05:19 PM
93EH6
Guest
Posts: n/a
Thanks guys i got it off
Old 12-02-2003, 05:20 PM
99blackcivicSi's Avatar
Default Re: How to remove steering wheel??? (shaun311)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaun311 &raquo;</TD></TR><TR><TD CLASS="quote">
Let the residual charge come off of the system for an extra 10-20 min!!!!!!!!!!!!!
qwrty
10-29-2009 01:55 PM
dustin_crxsi
10-30-2006 05:29 PM
active_motorsports
02-24-2004 10:35 PM
b18c1delly
12-22-2003 07:22 PM
phantom_sol
08-29-2003 12:54 PM
Quick Reply: How to remove steering wheel???
