How to remove An EG dash - Honda-Tech
Old 07-17-2007, 11:52 AM   #1
Default How to remove An EG dash
I GOT RID OF MY HATCH AND GOT A MOTORCYCLE SO I CANT TAKE NEW PICS SO....... I MADE ONE.
First off take the steering wheel off its not hard you only take out 2 star screws on the side of the wheel.
When those are out take out the airbag and unplug it.
When that is out then take out the large bolt in the middle.
Then the blinker switch and the windsheild wiper switch comes out but you have to unscrew 2 screws and take a flathead stick it here.
now take out the section where the cigarrette plug in is(4 screws 2 on top and 2 on the side)Take out the screw wen off
Then take out the glove box which is not hard there is like 4 screws.
You will need to take out the speed ometer.
Now on the top of the dash(middle) is that vent thing. pop that off with a flathead from the side. When off take out the screw(I think they are all 10 mm or maybe 12mm)
Now to take out the passenger air bag when the glove bx is out look under there and you will see 6 bolts that need to be taken out.
take out your stereo, unplug the wires on the driverside underdash fuse box.
Now work the dash board off and unscrew or unplug anything holding back.
now on both sides there are screws under the caps.
Modified by T Rick at 12:18 PM 7/17/2007
Modified by T Rick at 11:27 PM 10/21/2008
T Rick is offline   Reply With Quote
Old 07-17-2007, 12:24 PM   #2
Sick writeup!! I was looking for one....Good job
PS:Nice sandals :-p
Felliph3 is offline   Reply With Quote
Old 07-17-2007, 12:39 PM   #3
MagnaniEG6's Avatar
Default Re: (Felliph3)
MagnaniEG6 is offline   Reply With Quote
Old 07-17-2007, 12:39 PM   #4
i new somebody would see those. i live in oregon and its pissin rain outside. well somebody needed help so put on my gals sandles and took a few snaps
Old 07-17-2007, 12:50 PM   #5
perseverance's Avatar
thx bro, as soon as i get some more money... i'm gonna go get a black interior from a salvage yard. hopefully this write up will help out. anyway u can give more info on taking off the steering wheel?
perseverance is offline   Reply With Quote
Old 07-17-2007, 01:15 PM   #6
bara6075's Avatar
Default Re: How to remove An EG dash (T Rick)
bara6075 is offline   Reply With Quote
Old 07-17-2007, 01:44 PM   #7
instructor74's Avatar
Default Re: How to remove An EG dash (bara6075)
THIS IS HUGE before you unhook the air bag plugs you must disconnect the neg battery terminal and wait 5 mins or longer. It is now safe to unplug the air bags make sure you install the safety jumper to keep the air bag from being set off be accident.
instructor74 is offline   Reply With Quote
Old 07-17-2007, 01:49 PM   #8
Default Re: How to remove An EG dash (instructor74)
o ya forgot you must unhook your battery and to take off the steering wheel there are side plastic peices that come off and there are star screws on each side that you unscrew when the are out take out the center of our steering wheel(airbag) unhook the plug and the take out the huge bolt on your steering wheel(Not hard to miss) Then its off
Old 07-17-2007, 01:53 PM   #9
Quote:
Damn it, i was going to type that too but my internet went down and when it went back up i forgot. But yea be very careful or it will activate on your *** and knock you out for like 5 minutes.
Old 07-17-2007, 02:11 PM   #10
jus_spooln_wicha's Avatar
Default Re: How to remove An EG dash (Felliph3)
is that a jdm climate control?
a href="http://photobucket.com" target="_blank"></a>
jus_spooln_wicha is offline   Reply With Quote
Old 07-17-2007, 02:34 PM   #11
methos713's Avatar
Default Re: How to remove An EG dash (jus_spooln_wicha)
Should sticky this. By the way, how what does the safety jumper look like? Can't you just unplug the srs plug underneath the dash?
methos713 is offline   Reply With Quote
Old 07-17-2007, 03:45 PM   #12
get a 4 puck clutch and some motor mounts and launch ! ur dash will come right off ! b carefull might land in ur lap !
1.8L_allmotormilitia is offline   Reply With Quote
Old 07-17-2007, 05:41 PM   #13
Default Re: How to remove An EG dash (methos713)
Quote:
It should be attached to the access panel on the bottom of the steering wheel . open that panel disconnect the yellow plug remove the red plug from the panel and insert into the air bag plug
Old 07-17-2007, 06:18 PM   #14
methos713's Avatar
didn't know there was a red plug there...hummm, I'll go check. Thanks.
Old 07-17-2007, 07:50 PM   #15
TTacous's Avatar
Thanks for the write up. Now I don't have to break things taking out my dash
TTacous is offline   Reply With Quote
Old 07-17-2007, 09:23 PM   #16
* B A N N E D *
FYI: you do not have to remove the guage cluster and bezel in order to remove dash.
akunamatta is offline   Reply With Quote
Old 11-21-2007, 03:52 PM   #17
ydoubleonie's Avatar
coooll... but the pics are down. can you put em back up?
ydoubleonie is offline   Reply With Quote
Old 11-21-2007, 03:58 PM   #18
Syndacate's Avatar
I added it to the FAQ, get your pictures working.
If you need somebody to get 'em hosted for ya PM me.
Syndacate is offline   Reply With Quote
Old 12-16-2007, 01:03 PM   #19
srg
srg's Avatar
pics don't work can someone correct links?
srg is offline   Reply With Quote
Old 01-20-2008, 09:32 PM   #20
StoryBookSin's Avatar
nice write up THx
StoryBookSin is offline   Reply With Quote
Old 01-20-2008, 09:36 PM   #21
pemd5555's Avatar
Default Re: (StoryBookSin)
nice write up bump thanks
pemd5555 is offline   Reply With Quote
Old 02-16-2008, 07:42 PM   #22
ajaxK1's Avatar
Default Re: (pemd5555)
someone correct the pic links please.....
ajaxK1 is offline   Reply With Quote
Old 02-16-2008, 07:46 PM   #23
BlueIntegraBoy's Avatar
Default Re: (ajaxK1)
Quote:
BlueIntegraBoy is offline   Reply With Quote
Old 06-24-2008, 02:00 PM   #24
denraweb's Avatar
Default Re: (BlueIntegraBoy)
Can someone fix the pics? This would be a great write up if there were working pics...
denraweb is offline   Reply With Quote
Old 09-29-2008, 05:53 PM   #25
iluvmyEJ1's Avatar
hey can you redo your pic?? it would help out alot! thanks.
iluvmyEJ1 is offline   Reply With Quote
Hatchback maaco Paint job build thread!! T Rick Paint and Body 44 08-09-2009 10:17 PM
My f3 front end conversion to F4i T Rick Honda Motorcycles 13 11-03-2008 11:13 AM
Lowered civic traction control (spike Spider) T Rick Northwest (Sales) 4 05-09-2008 02:29 PM
EG part sale!! T Rick For Sale 24 04-20-2008 06:13 PM
WTB: Random interior peices for EG T Rick Northwest (Sales) 18 04-11-2007 10:08 PM
Tags
1992, 1994, 2000, 93, air, civic, dash, dashboard, honda, instructions, removal, remove, removing, si, vent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
