How to remove delsol door panel?
Old 02-24-2003, 10:15 PM
New User
eddie1681's Avatar
Default How to remove delsol door panel?
I removed many civic door panels, but I have trouble with this Delsol door panel.
Do you remove the power window switches and the handle? If so how can I do that?
Thanks
Old 02-24-2003, 10:18 PM
jdmsol's Avatar
Default Re: How to remove delsol door panel? (b20z)
Leave the switches in and unplug them once the panel is somewhat loose. The handle itself you have to twist just a little bit and let it slip through the panel. Does that help you any?
Old 02-24-2003, 10:27 PM
New User
eddie1681's Avatar
Default Re: How to remove delsol door panel? (jdmsol)
oh I mean the bottom handle, I can seem to pull it off
Thanks
Old 02-24-2003, 10:33 PM
jdmsol's Avatar
You don't need to pull it off to remove the panel. There should be a screw/bolt behind it, one screw behind the upper handle/by the lock and one on the edge of the panel closest to the A pillar. The rest should be clips along the edge of the panel. The lower handle can't be removed until you see the back side of the panel...if you can even do it then, I can't remember.
themurrell
02-21-2007 08:32 PM
96teggynonVtec
02-18-2006 02:22 PM
206civic
01-08-2005 11:43 AM
*Boostwerks*
09-13-2002 08:52 AM
teg95
05-22-2002 01:16 PM
Quick Reply: How to remove delsol door panel?
