How To: Not Get Ripped Off When Buying a Transmission
<FONT SIZE="3">How To: Not Get Ripped off When Buying a Transmission</FONT>
Yesterday I was lucky enough to see a local seller in the marketplace offer a <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by User name is safe for now »</TD></TR><TR><TD CLASS="quote">SOHC EX TRANNY REALLY LOW MILES. NO GRINDS THAT I KNOW OF</TD></TR></TABLE>
'Well look here, that sure would be nice to have that if the price is right." So I contact the seller, meet up, and ask a couple dozen questions, inspect the exterior and figure out, it looks good, here's your money. The only thing that threw me for a loop was the transmission ID stamp which read P20/A000, a small bearing case.
"Are you sure that's an EX/SI transmission, as I'm 100% sure that means otherwise."
"Ya, it does."
Since I've seen Honda do stranger things in my day, and the price was right I picked it up promising though to contact him with my findings once I popped opened the case.
Step 1: Look at transmission stamp. P20/A000 = Small Bearing, P20/B000 = Large bearing.
Well, that solves it right there, he sold me the wrong transmission. But wait, there's more:
Step 2: Identify Transmission definitely
Odd...after looking around Honda-Tech for a bit I could not find information on whether the JDM D15B definitely had a A000 / B000 case. Only one way to find out.
Step 3: Remove transmission housing
12x12mm bolts, pretty easy actually.
Step 4: Continue removing transmission housing
Big 3/8 drive bolt, use a breaker to guarantee removal.
Step 5: Stare blankly at countershaft C-Clip
Crap.
Step 6: Remove transmission housing from clutch house
The goal here is to count the teeth on the differential ring gear and then divide them by the teeth present on the counter-shaft. I see 69 teeth on the ring.
Step 7: Make sure all gears are present and accounted for
Or not, let's take a closer look.
W
T
F
How do you do that, really?
Step 8: Count teeth on countershaft
Normally its much easier to remove this from the housing, but I couldn't find my allen wrench. So what I did was make a mark on the gear face with a sharpie and then spin and count.
End result, 17 teeth.
What did I learn from this?
- Trust gut instinct, just because it could be something else assume it's not.
- I was sold a transmission with an obliterated fourth.
- I was sold a transmission that didn't have the correct final (69/17 = 4.058)
End Result
- Always do your research before hand, and never assume something that you buy will work as advertised.
"Ya, it does."
Crap.
W
T
F
End Result
Re: (lmananT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmananT »</TD></TR><TR><TD CLASS="quote">that things junk! did you get your money back?</TD></TR></TABLE> Well, I did want to have a spare 4.058 F/D for my upcoming close ratio transmission build but not for this price. I have contacted the seller to seek a friendly solution to this, but I have not heard back from him yet. For now I am giving him the benefit of the doubt and not doing anything rash and yelling "XXXX IS A SCAMMER BLA BLA BLA." I just hope others can learn from this, and maybe realize as well taking apart a transmission to take a look around isn't that hard.
sorry to hear, i too have a dx trans that was sold to me as an ex, when i first started working on hondas, but not in as bad condition.
that A000 stamp is not going to lie!
dr_latino999
16
07-09-2008 06:25 PM
srogan88
03-18-2003 06:56 PM
