how much oil for b16a2?
how many quarts of oil in the b16a2 OBDI?
sorry, doing the swap and feel stupid ... been up for 26 hours and counting...
almost done
*yawn*
almost done
*yawn*
be professional
Re: how much oil for b16a2? (Sketch_hs)
Owners manual states that the B16A takes 4.2 quarts when you change the oil and filter.
I think it takes 5.1 quarts for an engine rebuild.
ive noticed at work the following oil capacity in quarts....
b16a: 4.25-4.5
b18c1: 4.5-4.75
b18c5: 4.5-4.75
b18b: 4.25
b17a: 4.5
b20: 4.5
d16y: 3.5
d15: 3.5
d17: 3.5-3.75
f23: 4.5
f22: 4
h22a: 4.75-5.25
h23a: 4.5-4.75
k20a2: 5.00-5.25
k20a3: 4.75-5.00
Modified by SleepnCiViC at 8:35 PM 12/6/2003
b16a: 4.25-4.5
b18c1: 4.5-4.75
b18c5: 4.5-4.75
b18b: 4.25
b17a: 4.5
b20: 4.5
d16y: 3.5
d15: 3.5
d17: 3.5-3.75
f23: 4.5
f22: 4
h22a: 4.75-5.25
h23a: 4.5-4.75
k20a2: 5.00-5.25
k20a3: 4.75-5.00
I put 4 in mine, warm the car up and recheck...should be just about right......might have to add just a scoch
Re: how much oil for b16a2? (h22John)
i jsut rebuilt my friend b16a2 and we used 4.75 quarts, its cause we rebuild the engine and there wasnt alot of oil inside. so im guessing 4 quarts if its not a rebuid b16 and 4.75 if the b16 has been rebuilt. just check your dip stick.
Re: how much oil for b16a2? (stock93cx)
what K20 motor doesn't have i-vtec?
i mean...i thought all k20's had i-vtec (K20A[JDM ITR], K20A2[CTR,ITR,Type-S] K20A3[Si])
im really curious if there is one...and if so, what car does it go in?
Re: how much oil for b16a2? (JUN EK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN EK9 »</TD></TR><TR><TD CLASS="quote">what K20 motor doesn't have i-vtec?
im really curious if there is one...and if so, what car does it go in?</TD></TR></TABLE>
im sorry i had a brain lapse when i typed that in fo it should say k20 types and k20 non type s. i will edit it now
be professional
Re: how much oil for b16a2? (blue_b16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue_b16 »</TD></TR><TR><TD CLASS="quote">dont put more than 4L in your motor, @ Honda we put 4L in all B-series</TD></TR></TABLE>
Quite interesting then that my Honda Owner's Manual states to use 4.2 quarts with a filter change. Also interesting that the larger B-blocks take even more oil.
Does Honda know you are doing this?
Edit: damn you and your metric measurements! My mistake, sorry. You said 4 liters, not quarts.
Modified by Targa250R at 9:14 AM 12/8/2003
be professional
Re: (SleepnCiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC »</TD></TR><TR><TD CLASS="quote">if liter is the same capacity as quarts then your defenatly short changing some b-series motor from oil. </TD></TR></TABLE>
4.20 quarts = 3.97 liters, 4.00 liters = 4.23 quarts.
Guess they aren't.
Guess they aren't.
Re: (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
Guess they aren't.</TD></TR></TABLE>
ok thats sounds a little better but most be series motor still take more than that. my c5 has taken a little less than 5 before
Former Moderator
Re: how much oil for b16a2? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">Owners manual states that the B16A takes 4.2 quarts when you change the oil and filter.
I have always put 4.25 in my fiancee's B16A2 and it is always right on the money.
I've probably changed more oil than most people in this topic too seeing as how I've been at this shop for about 3 years now. I've seen my fair share of B16A oil changes.
Re: (SleepnCiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC »</TD></TR><TR><TD CLASS="quote">4.5, all vtec b-series motor are about 4.5</TD></TR></TABLE>
Re: (Sketch_hs)
IF U DONT KNOW HOW MANY QTS OF OIL U NEED IN UR CAR....I DONT THINK U SHOULD BE DRIVING...EVEN MY GIRL CAN CHANGE HER OIL .... HAHAHHAA
be professional
Re: (Junkiii Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Junkiii Eg »</TD></TR><TR><TD CLASS="quote">IF U DONT KNOW HOW MANY QTS OF OIL U NEED IN UR CAR....I DONT THINK U SHOULD BE DRIVING...EVEN MY GIRL CAN CHANGE HER OIL .... HAHAHHAA</TD></TR></TABLE>
If you don't know how to use the Caps Lock, I don't think you should be using a computer. Even my grandmother can use the Caps Lock. Ahaha.
