How much to have piston rings replaced?
Old 01-05-2006, 12:27 PM
gunner6696's Avatar
Default How much to have piston rings replaced?
How much does it cost to have your piston rings replaced? I got a 2000 civic dx which i think needs new piston rings. Is it hard to do yourself or just time consuming? let me know asap anyone because i need the car for school. thanks
Old 01-05-2006, 12:30 PM
.Ry
.Ry's Avatar
Default Re: How much to have piston rings replaced? (gunner6696)
I need my oil rings changed as well. I have heard of people dropping the oil pan, and pulling the head and doing it that way. Not sure how easy that is. I dont think there is a write up. I did find this shady DVD: http://cgi.ebay.com/ebaymotors...wItem If you mess it up, there is gonna be some problems. If you havent done it before have someone either help you who has, or have a mechanic do it. I would say anywhere from 1K-1600K for a mechanic. Whats wrong with the engine now??
Old 01-05-2006, 12:31 PM
Civicse's Avatar
how do you know it needs new rings?
Old 01-05-2006, 12:54 PM
x_outlaw_x's Avatar
i have pistons and rings for that engine with rods and bearings and all that stuff for 10 dollars...pulled out of a running engine with good compression
Old 01-05-2006, 12:55 PM
00CivicGirl's Avatar
Default Re: How much to have piston rings replaced? (Civicse)
Yea before you go through all the trouble make sure you need piston rings..unless you dog the heck outta your car i dont see a 5 yr honda needing them..
anyways here for our b18 it was $30 to replace the rings and $30 to hone the block. The shop said the block needed to be honed if they replaced the rings.. i dunno we havent gotten it done yet lol either way the block had to be out the car for them to do it
Old 01-05-2006, 01:50 PM
.Ry
.Ry's Avatar
Default Re: How much to have piston rings replaced? (00CivicGirl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00CivicGirl &raquo;</TD></TR><TR><TD CLASS="quote">Yea before you go through all the trouble make sure you need piston rings..unless you dog the heck outta your car i dont see a 5 yr honda needing them..
anyways here for our b18 it was $30 to replace the rings and $30 to hone the block. The shop said the block needed to be honed if they replaced the rings.. i dunno we havent gotten it done yet lol either way the block had to be out the car for them to do it</TD></TR></TABLE> My 97 EJ8 has 123,000 miles on it and it needs oil controll rings. Compression is high but you can oil on a few of the sparkplugs. Yeah I bet it would be $30 if they just had the block.
Old 01-05-2006, 02:17 PM
gunner6696's Avatar
Default Re: (x_outlaw_x)
I'm not sure if its that but my 3rd cylinder is low on compression and i was told the other were a lil low also. the exhaust is not dark or anything, it looks like the smoke is normal but my 3rd cylinder isnt working/missfiring. im pulling of the head tommarrow to find out, any thing to look for? i was thinking maybe the head gasket went? i was an idot and tryed putting larger injectors in and seeing if i would work without a AFC and i was running extremely rich, if anyone has any suggestions let me know. im working in a shop with all mopar people and they keep saying i should just forget tryint to fix a honda, so i need to prove them wrong. ( i am vtecing and putting a turbo in also to show them u can do tha on a 4cylinder, they got the idea its gonna just blow up my block.) THANKS FOR THE HELP SO FAR EVERYONE
Old 01-05-2006, 03:20 PM
.Ry
.Ry's Avatar
Default Re: (gunner6696)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunner6696 &raquo;</TD></TR><TR><TD CLASS="quote"> ( i am vtecing and putting a turbo in </TD></TR></TABLE> What the hell is vtecing? IT has VTEC or it doesnt.
Old 01-05-2006, 03:38 PM
gunner6696's Avatar
Default Re: (turner7205)
Its also called a mini me swap, i drop a d16y8 head which is vtec and place it on a d16y7 block, you get about 21 hp i was told. Its really cheap compared to a complete swap.
Old 01-05-2006, 03:41 PM
x_outlaw_x's Avatar
you will just blow up your block if its not done right...like turboing a block with bad rings in it
Old 01-05-2006, 04:31 PM
.Ry
.Ry's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunner6696 &raquo;</TD></TR><TR><TD CLASS="quote">Its also called a mini me swap, i drop a d16y8 head which is vtec and place it on a d16y7 block, you get about 21 hp i was told. Its really cheap compared to a complete swap. </TD></TR></TABLE> You just want madd VTAKK dont ya? I honestly would save up for a real swap. I have a D16Y8 and its still slow. You dont reall even hear VTEC engage. It burns oil now, look for another motor to rebuild and toss in.
Old 01-05-2006, 06:12 PM
gunner6696's Avatar
do you know what could be the reason why i have a missfire in my 3rd cylinder? and do you know the compression each piston should have?
Old 01-05-2006, 06:55 PM
x_outlaw_x's Avatar
my d15b has around 175 i think
Old 01-05-2006, 07:01 PM
gunner6696's Avatar
cylinders 1,2,4 have 90 and cylinder 3 has 60 (it say misfire only in cylinder 3 though) ... What do you think is wrong? I was guessing a head gasket, i tryed to put larger injectors in and i was running extremely rix and pulled them and put the stocks back in.
Old 01-05-2006, 07:04 PM
.Ry
.Ry's Avatar
90psi? Holy ****. Pull the head and look at your gasket. IS there like a vaniila pudding substance in your valve cover? Sounds like you need either a new head gasket or new pistons/rings.
Old 01-05-2006, 07:11 PM
x_outlaw_x's Avatar
yeah 90 isnt good...i think it is your piston rings...might be wrong but it could also be some fucked up *** valve seals
Old 01-05-2006, 08:37 PM
dunkd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x_outlaw_x &raquo;</TD></TR><TR><TD CLASS="quote">i have pistons and rings for that engine with rods and bearings and all that stuff for 10 dollars...pulled out of a running engine with good compression</TD></TR></TABLE>
just buy new OEM stuff.
Old 01-05-2006, 08:59 PM
x_outlaw_x's Avatar
the engine only had 30k on it...i was going to put them in my d15b to bump compression up but switched back to b series
Old 01-06-2006, 07:40 AM
.Ry
.Ry's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">
just buy new OEM stuff.</TD></TR></TABLE>
What lasts longer in a daily driver? OEM parts from Honda, or Wiseco or places like that fine?
Old 01-06-2006, 08:13 AM
gunner6696's Avatar
I am dropping a rebuilt head, if its bad valves seals i wouldnt have to change anything right? how can i tell if the rings are bad, the valves seals, or the gasket? thanks for everything so far.
Old 01-06-2006, 05:48 PM
x_outlaw_x's Avatar
is it smoking?
Old 01-12-2006, 04:51 PM
gunner6696's Avatar
It is not the RINGS!!! The head gasket didnt look that bad so what else could it have been? Im placed a new head on but not done bolting everything back up and timing it. THANKS FOR ALL THE HELP SO FAR
Old 01-12-2006, 06:18 PM
Civicse's Avatar
did you try a new head gasket to see if it will hold comp? u might not be able to tell just by looking at it. and how about the valve seals?
Drag-On
04-06-2004 11:52 AM
riceball777
01-17-2004 09:41 PM
Aeka GSR
09-28-2003 11:15 AM
non-VTEC
10-26-2002 08:15 AM
Islander
10-11-2002 02:45 AM
Quick Reply: How much to have piston rings replaced?
