How much freon does my 96 civic dx coupe need to work properly? - Honda-Tech
Old 05-31-2010, 07:37 PM   #1
Default How much freon does my 96 civic dx coupe need to work properly?
as the title says i would like to know how much freon (lbs) does my car need it is empty just reinstalled it yesterday after i did my swap in feb thanks in advance
jdmstyleEJ6 is offline   Reply With Quote
Old 05-31-2010, 09:46 PM   #2
Default Re: How much freon does my 96 civic dx coupe need to work properly?
bump
Old 05-31-2010, 10:10 PM   #3
D16SiHatch's Avatar
0 lbs of freon.
it does however use tetrafluoroethane aka r134a
iir the system should take about 1.4lbs (22oz.) of refrigerant.
make sure you pull a vacuum on the system first before trying to fill it. i can't tell you how much easier this process is with one of these buggers lol
D16SiHatch is offline   Reply With Quote
Old 05-31-2010, 11:36 PM   #4
SeanK325's Avatar
bump for this one. i have to recharge my A/C, too. Is it absolutely necessary to pull a vacuum test prior to adding the refrigerant?
SeanK325 is offline   Reply With Quote
Old 05-31-2010, 11:48 PM   #5
well i dont know if its necessary or not but i have done it before with out the vaccum and my ac was pretty cold only reason i dont have it still is cause i did a swap. i jus neva new how much freon to put last time i guessed
Old 06-01-2010, 12:00 PM   #6
D16SiHatch's Avatar
http://www.youfixcars.com/car-ac.html
"it is highly recommended to remove any air and moisture from the system before you add a Freon charge.
Pulling a vacuum on the system does this. If you decide to skip this step, your air conditioning may work after recharging, but the question is for how long.
Air in the system restricts the refrigerants ability to change its state from a gas to liquid and can cause pressure problems and lower the cooling efficiency of the car ac.
Moisture on the other hand can cause freeze ups, and also restrict the refrigerant flow. Moisture can also form an acid when mixed with refrigerant.
This will cause corrosion inside the system. An a/c vacuum pump connected to a manifold ac gauge set will remove all of this air and moisture from an empty system. You must recover the remaining Freon from the car air conditioning system before you pull a vacuum."
Old 06-01-2010, 05:29 PM   #7
SeanK325's Avatar
^^ so how do i run a vacuum test without the fancy machine you have there?
Old 06-01-2010, 06:00 PM   #8
Anon51's Avatar
Quote:
go to an auto parts store that'll let you rent a vacuum for ac. aka autozone
Anon51 is offline   Reply With Quote
Old 06-01-2010, 06:11 PM   #9
SeanK325's Avatar
Quote:
ok thanks.
Old 08-05-2010, 11:02 AM   #10
I have a '94 Accord and, I just replaced my high pressure receiver pipe due to a hole and tried recharging through the low pressure port. However, I have put in 42 oz. of r-134a and nothing has changed. Hot air is still blowing from the vents and gauge reads 10-15 ps,i and the needle continues to drop every time I check it. There is no leak, so I don't know why several cans of r-134a seems to have no effect. Should I continue to add more refrigerant? I"m afraid to over charge it.
redheadryan73 is offline   Reply With Quote
Old 08-05-2010, 12:04 PM   #11
Quote:
Your system requires less than half this amount of refrigerant.
Former User is offline   Reply With Quote
Old 08-05-2010, 12:13 PM   #12
You overcharghed your system bro. By a lot! This is why it's blowing hot probably.
EJeff8 is offline   Reply With Quote
Old 08-05-2010, 12:16 PM   #13
I'd feel bad for the person who actually would try to put freon in their civic. 1. Where the hell will you find the damn freon? 2. It's highly poisonous. If they could find a better alternative to antifreeze, that would be illegal to sell like freon in a snap.
Old 08-10-2010, 12:07 PM   #14
willpower102's Avatar
1. ebay ? It's all over. Just because it can't be manufactured doesn't mean it's illegal to sell :/
So does anyone have some actual manifold gauge target pressures I should be hitting? I recently did an engine swap and I need to get this thing cool again. I did drain all the oil out of the compressor. I'm pulling a vacuum on the system right now. However there are no stickers telling me how much should go in.
It's a 92 civic 1.5
willpower102 is offline   Reply With Quote
Old 08-10-2010, 12:19 PM   #15
It's a 92 civic 1.5
If you have a stock system, it takes 21-23 oz of R12. When the system is empty, just add that weight of refrigerant. You should then be good to go.
Old 08-10-2010, 12:33 PM   #16
Does that include or exclude oil? eg, 22oz of r134a + 4oz of oil?
It's actually been retrofitted to r134a last year, so with the smaller older compressor, it will never cool as well as it should with r12. Are those numbers still correct or should i go with the 85% rule?
Old 08-10-2010, 12:40 PM   #17
The Civic stock R134a system takes about 22 oz of refrigerant not including oil.
Leaking freon curtie94 Honda Accord (1990 - 2002) 7 05-31-2011 10:31 PM
Refilling R134 freon question schueytenten Honda CRX / EF Civic (1988 - 1991) 2 09-24-2009 01:04 PM
R12 or 134a onsetofpurity Honda Civic / Del Sol (1992 - 2000) 23 04-21-2009 03:53 PM
How much Freon? crj_lll Honda Prelude 6 10-07-2006 12:22 PM
R134a A/C re-fill for my 94 coupe h22xcivic Honda Civic / Del Sol (1992 - 2000) 2 10-09-2005 07:23 PM
Tags
08, 94, 96, 98, accord, air, car, civic, conditioning, freeon, freon, honda, put, recharging, refrigerant, video
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
