How much does camber and toe effect steering? - Honda-Tech
Old 11-17-2004, 09:24 PM   #1
JDMhatchback20's Avatar
Default How much does camber and toe effect steering?
So here is the deal. My car is pretty low, i'm tucking the front and rear tires by a little bit. I have a camber kit (omnipower) and have been playing it by eye on the camber since winter is comming up and i'm gonna just raise it and then get an alignment soon anyways.
Well, my steering is horrible, i don't feel safe driving it at all right now and i was wondering if the camber and toe are factors of that, which i'm sure they are. I just want to know what you all think and if after you got an alignment it helped at all.
Also, what should i as for when getting an alignment. Should i have -1 degree of camber and 0 of toe?
Let me know what i should do!!!!!!! thanks!
JDMhatchback20 is offline   Reply With Quote
Old 11-17-2004, 09:30 PM   #2
SOHC4life 96's Avatar
Default Re: How much does camber and toe effect steering? (JDMhatchback20)
The camber won't affect your stearing as much as it will wear your tires fast as ****. Don't get me wrong though, it will still affect your steering.
As for the toe angle, I'm betting that is more the problem. Getting an alignment will do a great deal for your steering.
When you get the alignment, you usually want to have a little toe in on the front wheels. The camber I'm not sure about though.
SOHC4life 96 is offline   Reply With Quote
Old 11-17-2004, 10:06 PM   #3
sleepingEg8's Avatar
Default Re: How much does camber and toe effect steering? (DOHC4life)
Camber is not really the wearing alignment angle. Toe is the ultimate wear on the front tires. But when you combine excessive toe setting with negative camber when you drop the car, your tires will definately suffer. An incorrect toe setting will not cause your car to pull, an incorrect camber setting will. Do align your car though, You will love it.
sleepingEg8 is offline   Reply With Quote
Adding camber kit, will it change toe? TOO MUCH TORQUE Suspension & Brakes 3 12-24-2010 03:44 PM
Camber Kits are a MUST: Over-steering and Skidding on 98 Integras tiresias Acura Integra 18 11-11-2009 08:34 AM
Alignment Question after lowering car .brian. Acura Integra 18 01-17-2006 11:35 AM
Cheaper way to do alignment? elpiar Suspension & Brakes 3 04-30-2005 11:41 AM
Alignment for 96-00 Civic w/ 5 lug conversion EricUSC Honda Civic / Del Sol (1992 - 2000) 7 04-30-2003 08:44 AM
Tags
acura, adjusting, affect, alignment, camber, car, degree, effect, effects, eg6, incorrect, steering, toe, toein, woundering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
