ECU code 21 (VTEC solenoid), why why why!?
Old 11-17-2004, 03:50 PM
VTC_CiViC's Avatar
Default ECU code 21 (VTEC solenoid), why why why!?
Here's the situation, I just swapped my '98 D16Y8 into a '94 CX hatch. I ran the VTEC solenoid wire to ECU pin A4 (P28), and disabled the VTEC pressure sensor via Uberdata, yet when I start the car, I get a code 21 which indicates a fault with the solenoid. Is there any other trick I missed?? The solenoid is plugged into the A4 pin but I still get the CEL.. help?
Old 11-17-2004, 03:56 PM
JDMlyfestyle's Avatar
code 21 is the vtec spool solenoid valve. so when you dissabled the vtec pressure solenoid you basically took 1/2 of the function away from the vtec solenoid. that pressure switch is important. it wont allow your engine to hit vtec unless you have a least 55 psi of oil pressure. so i would reactivate the pressure switch.
Old 11-17-2004, 04:25 PM
DJ_SaNdOz's Avatar
Default Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">code 21 is the vtec spool solenoid valve. so when you dissabled the vtec pressure solenoid you basically took 1/2 of the function away from the vtec solenoid. that pressure switch is important. it wont allow your engine to hit vtec unless you have a least 55 psi of oil pressure. so i would reactivate the pressure switch.</TD></TR></TABLE>
That is correct for a US ECU that looks for the pressure switch. He used a custom ECU ROM w/ the pressure switch disabled.
Are you sure that the solenoid is good? Is the wire hooked up correctly in the ECU harness w/ an ECU pin?
Old 11-17-2004, 08:39 PM
VTC_CiViC's Avatar
Default Re: (DJ_SaNdOz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz &raquo;</TD></TR><TR><TD CLASS="quote">
Are you sure that the solenoid is good? Is the wire hooked up correctly in the ECU harness w/ an ECU pin?</TD></TR></TABLE>
Well I went ahead and did some more poking and prodding and with the help of a friend I got it working. I'm guessing there was simply a faulty connection at some point because I was registering 12v at the solenoid with the engine stopped and the key 'ON', naturally that's not supposed to happen. Did a little re-tracing of the wiring and viola! No more code 21, now i'm just stuck with a stupid code 14 for the IACV
Stupid Hondas...
Old 11-17-2004, 08:53 PM
Risky Business
BauleyCivic's Avatar
Default Re: (VTC_CiViC)
Glad you got it working
Old 11-17-2004, 09:05 PM
pydwy213's Avatar
daaaaaaaaamm foo knows his ****
keychild486
11
04-02-2008 06:28 AM
obuhmyuh
02-26-2008 10:07 AM
95exr
06-28-2004 06:25 PM
InfamousRS
05-21-2002 04:09 PM
Quick Reply: ECU code 21 (VTEC solenoid), why why why!?
