more power out of a DD
Old 06-20-2009, 09:24 PM
DEATHB4DlSHONOR's Avatar
Default more power out of a DD
i currently have i/h/e on my em1. i would like to get some more power out of my car. keeping in mind this is my DD so reliability is a must. i am open to any suggestions on what to upgrade next if you think there is a better route. i just want some more power out of the car without taking away the reliability. thanks
Old 06-20-2009, 09:27 PM
NACvicSi's Avatar
Default Re: more power out of a DD
not much n/a. A forced induction setup tuned right is just as reliable.
Old 06-20-2009, 09:29 PM
Ruben19's Avatar
b16 are hella slow.
either do a poor mans r or get a supercharger.
Old 06-20-2009, 09:31 PM
Ruben19's Avatar
buddy is right ^
NACvicSi's Avatar
Why a supercharger? Turbo kits can be had way cheaper and just as reliable.
Old 06-20-2009, 09:39 PM
CivicSpoon's Avatar
I'm willing to bet, pretty much everyone is going to say for you to turbocharge it.
Old 06-20-2009, 09:48 PM
batallic's Avatar
turbo is reliable if done right
Old 06-20-2009, 09:53 PM
ok so if a b16 isnt the route to go then maybe a b18? or like someone said a poor mans r? my only question to that is if i drop a new motor in do i have to beef up anything else to handle the transition?
Old 06-20-2009, 09:55 PM
batallic's Avatar
which b18, GSR, type-r, or b18b, u can reuse everything but the ECU, but for the price of a swap u can boost
Old 06-20-2009, 09:57 PM
Linked's Avatar
if your gonna go turbo then he might have to get rods or valve seals for reliability (depending on how many miles you have on your car now)
Old 06-20-2009, 09:59 PM
NACvicSi's Avatar
He more than likely has to get new piston rings before either of those.
Old 06-21-2009, 07:46 AM
the car has 99k. i would be willing to turbo as long as its not going to hinder the reliability. i am open to everything at this point. i just want to some more power when i hit the gas.
Old 06-21-2009, 09:59 AM
Slow_import's Avatar
i think ctr/itr cams and valve train with a descent header and nice tune should get you what you want. Remember no matter what you do to a b16, it will always feel sluggish, but theres a difference between feeling like your going fast and actually going fast.
the b16 is a motor that dont feel like your going fast b/c of the lack of torque, but with itr/ctr cams, a good header, and a nice tune the car will really open up.
Old 06-21-2009, 10:15 AM
tw1tch's Avatar
Any power you add to the car beyond what it came with stock from Honda will bring reliability into play. A turbo setup with an A+ tune and a bulletproof motor will still be less reliable than stock. Upping the power in any way will bring the reliability down to different degrees. Turbo the b16 now, and build another motor at the same time. If you tune it right and can resist turning up the boost too high, it'll last you a few years and then you can throw in a nice built motor and go kick some ***. NA will leave you pissed off unless you have at least 2 liters. K20, b18 bored out etc.
Old 06-21-2009, 01:03 PM
Bwill9886's Avatar
Well said. You have to be willing to spend the money to keep your car reliable and to make the power you want.
Old 06-21-2009, 01:25 PM
NACvicSi's Avatar
Do a H2B swap. You have big chunk of the parts since you have a EM1.
Old 06-21-2009, 02:41 PM
gearhead16's Avatar
y does everyone hate b16s... ive got two of them one in my dd 99 em1 and 1 in my 11 sec crx ... both of them run dam. good my coupe went 15.2 on crappy tires and 87 pump gas and on a crappy track. ... and full interior
Old 06-21-2009, 02:42 PM
gearhead16's Avatar
x2 on the h2b tho h2b=badass. im currently building one.
Old 06-22-2009, 08:41 PM
batallic's Avatar
all u need is the adapter plate and the engine
SIsamson22
35
05-09-2010 12:20 AM
jmader19
03-05-2008 03:09 PM
B16Civic93
05-17-2005 08:13 PM
llxzxll
10-26-2004 11:48 PM
Tex Blackwell
07-30-2004 06:01 AM
Quick Reply: more power out of a DD
