How Much is a B20 VTEC Build?
The full Cost.
B20B, Harness, ECU, everything. How much will it all cost me to do this? I have a B16A JDM right now so I don't have to pay for the head. I just want a quote from someone who thinks they may know the price to do this. Thank you.
Re: How Much is a B20 VTEC Build? (Lil Gnome)
well first you will have to purchase the block ..($700-750 shipped)use your head and harness and purchase a golden eagle vtec kit..golden eagle kit is ussually around $200 but you can always find the parts piece by piece and save some $$.if its a ek you can use a ex or si wire harness..keep that b16 head with manifold and all the other good stuff thats on the head..use a gsr or type r timing belt($30-50)use gsr or type r head bolts(?)shouldnt come out to much money..recomended to use arp rod bolts since you will bring up the rev higher then 6 or 7k rpm's.use gsr or type r oil pump and waterpump..
Yeah I am doing the same thing but with a b18 head, I just bought a b20 block for 750 locally but it has ge i beam rods and wiseco 84.5 mm pistons, crank, and arp head studs. I still need the baffle, oil pan, bearings, ect.
