How many AMPS does a stock civic radiator fan pull? - Honda-Tech
Old 11-16-2007, 07:37 PM   #1
1baddturbosi's Avatar
Default How many AMPS does a stock civic radiator fan pull?
I have a perma-cool radiator fan, think its pulling alot more amps than the stock fan is. causing my rad. fan relay to burn-up frequently!
1baddturbosi is offline   Reply With Quote
Old 11-16-2007, 08:01 PM   #2
TurboSI56's Avatar
Default Re: How many AMPS does a stock civic radiator fan pull? (1baddturbosi)
If you know anyone with a multimeter you can figure that out pretty easily.
TurboSI56 is offline   Reply With Quote
Old 11-16-2007, 08:09 PM   #3
Default Re: How many AMPS does a stock civic radiator fan pull? (TurboSI56)
sorry, but i said i have an aftermarket fan installed on the car, sooooo i dont have a stock fan to see how many its pulling.
i have a fluke multimeter & a amp clamp, im going to the garage to see the difference between what the stock fan pulls, compared to my permacool rad. fan
Old 11-16-2007, 08:13 PM   #4
* B A N N E D *
Quote:
I can check for you tomorrow,
Teknoshaman is offline   Reply With Quote
Old 11-16-2007, 08:22 PM   #5
Default Re: How many AMPS does a stock civic radiator fan pull? (Teknoshaman)
that would be a huge help
Old 11-17-2007, 10:46 AM   #6
I can confirm that my amp draw from my perma-cool fan is 9.5amps
Old 11-18-2007, 12:39 PM   #7
blessedrican's Avatar
dunno
blessedrican is offline   Reply With Quote
Old 11-18-2007, 12:47 PM   #8
95dxsir2's Avatar
yes, the radiator or condensor fan should only pull approx. 8-12 amps. some motors vary. it's been a year since i tested the last one, but thats a ballpark figure
95dxsir2 is offline   Reply With Quote
Old 11-18-2007, 01:30 PM   #9
gezzuzz's Avatar
the stock relay should hold that.. but you can always put your own relay
gezzuzz is offline   Reply With Quote
Old 11-18-2007, 02:35 PM   #10
Default Re: How many AMPS does a stock civic radiator fan pull? (gezzuzz)
the relay sometimes "buzz's" & vibrates. & i dunno whats exactly going on
Old 11-18-2007, 05:19 PM   #11
* B A N N E D *
Mine pulls 8.1 amps. Check to be sure the ground on the fan and the ground on the relay is good.
civic fan push or pull mikegeezy Honda Civic / Del Sol (1992 - 2000) 4 02-29-2008 06:52 PM
capacity of the stock fan relay??? gogunkergorilla Honda Prelude 2 01-10-2007 09:20 PM
Will stock radiator fan work with fluidyne radiator? SuicideSlide Honda Civic / Del Sol (1992 - 2000) 3 11-26-2004 09:53 AM
Fan Replacement B16 swap WTF!?! 6MTV6 Honda CRX / EF Civic (1988 - 1991) 17 06-22-2004 08:02 AM
Does the stock radiator fan push air, or pull? TenaciousC Acura Integra 1 09-10-2002 04:38 PM
Tags
amp, amps, buzz, civic, current, draw, fan, fans, honda, location, problem, pull, radiator, relay, si, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
