How to keep door seals and handles from freezing? - Honda-Tech
Old 01-16-2007, 02:00 PM   #1
globy123's Avatar
Default How to keep door seals and handles from freezing?
Hi..Do anyone know how to keep the door seals and handles from freezing? Can you use motor oil on the door seals?
globy123 is offline   Reply With Quote
Old 01-16-2007, 02:17 PM   #2
HT White Ops
Just keep a can of deicer handy. You can't keep them from freezing, you just have to be prepared when they do.
That, or just take the day off from school or work.
Eran is offline   Reply With Quote
Old 01-16-2007, 02:30 PM   #3
chrisw85's Avatar
vegetable oil, or a light coat of silicone lubricant; they sell it at any plumbing supply place.
chrisw85 is offline   Reply With Quote
Old 01-16-2007, 03:02 PM   #4
gezzuzz's Avatar
Default Re: (chrisw85)
move to a warmer place
gezzuzz is offline   Reply With Quote
Old 01-16-2007, 03:05 PM   #5
Chim Chim's Avatar
Default Re: (gezzuzz)
Try graphite lube for your door locks... It comes in a small toothpaste like tube...
For your door seals, try lubing them with 100% silicone spray... Or get used to kicking your door a couple times to get it open on icy mornings ...
Chim Chim is offline   Reply With Quote
Old 01-16-2007, 03:24 PM   #6
globy123's Avatar
Default Re: (Dagul)
Is it a good idea to use graphite lube on door seals?..I bought some an on the label it says it's good for rubber under extreme temps.
Old 01-16-2007, 04:42 PM   #7
Chim Chim's Avatar
Default Re: (globy123)
I probably would stick to silicone for door seals... graphite tends to get a little messy on a larger scale application like a door seal... I'd hate to get that stuff on on my clothes getting in and out of my car... The choice is yours...
Old 01-16-2007, 04:44 PM   #8
bart2546's Avatar
Default Re: (Chim Chim)
Agreed, use graphite inside the lock cylinder and silicone lubricant on the rubber seals.
bart2546 is offline   Reply With Quote
Old 01-16-2007, 04:58 PM   #9
globy123's Avatar
My question is would the graphite lubricant cause damage to the door seals? When I applied the lubricant, it seemed to dry off completely . I guess it froze from the (-18 degrees celcius) cold weather.
Old 01-16-2007, 05:03 PM   #10
bart2546's Avatar
Yea you wouldn't wanna put the graphite on the rubber part of the seals, unless it's in the velvet like area of the window tracks. But primariy keep it in the lock cylinder, and yes the silicone lubricant should look like it evaporates not unlike electronic parts cleaner. But if you run your fingers down after putting a good layer on it, it should feel slippery.
Old 01-16-2007, 05:35 PM   #11
globy123's Avatar
Default Re: (bart2546)
Crap..I put some of the graphite lubricant on the seal. I guess I'm gone have to wipe it off tomorrow and go buy some silicon lubricant for the seals.
Old 01-17-2007, 01:23 PM   #12
globy123's Avatar
Default Re: (Eran)
Would I still be experiencing the frozen car lock problem if I installed a keyless entry system?
Old 01-17-2007, 01:26 PM   #13
Darth ModerVader
Padawan's Avatar
Quote:
No.
Padawan is offline   Reply With Quote
Old 01-17-2007, 01:28 PM   #14
DelSolMarine's Avatar
Default Re: (Padawan)
blow torch
dont get any ideas im kidding... but autozone has a spray can stuff and it has a scraper on the edge that works on the locks and door not just the windows
DelSolMarine is offline   Reply With Quote
Old 10-26-2010, 02:10 PM   #15
globy123's Avatar
Default Re: freezing ice
Do you need to apply silicon lubricant every year around the door seals to prevent them from freezing?
Old 10-26-2010, 02:13 PM   #16
Seagull Management
94EG8's Avatar
Quote:
Depends on the vehicle I guess, i've never had an issue with my civic doors freezing shut, but I know guys with VWs that have all kinds of trouble. Best thing to do is clean the door jambs really well and wax them, the apply silicone spray to the rubber door seals.
94EG8 is offline   Reply With Quote
utility sink in garage builthatch General Discussion and Debate 4 03-08-2016 08:01 AM
Frozen door seal caused broken door handle Cheapshot1979 Paint and Body 0 02-04-2015 03:54 PM
08 Door Seals on Car (Not Door Itself) cueto Honda Civic (2006 - 2015) 2 03-16-2012 09:05 PM
how to avoid frozen doors? GetCaughtDead General Discussion and Debate 31 11-28-2004 12:32 AM
Need some help ButterMule Honda CRX / EF Civic (1988 - 1991) 2 11-07-2003 09:18 AM
Tags
car, civic, door, freezing, hadles, honda, jamb, knobs, lubricant, oil, prevent, seals, silicone, vegetable, wipe
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
