error code 22 with disabled vtec oil pressure switch
I have disabled the vtec oil pressure switch( the d6 cable goes from the ecu directly to the ground). But I have also error code 22. What could it be?
Here is my setup:
ported d16y8 head
105300 cam
1mm ferea bigger valves
zex valve springs
d16z6 IM
hondata gasket
b16 tb
d15b2 block
walbro 255lph
Here is my setup:
ported d16y8 head
105300 cam
zex valve springs
d16z6 IM
hondata gasket
b16 tb
d15b2 block
walbro 255lph
Re: error code 22 with disabled vtec oil pressure switch (eg4matze)
i've never heard of grounding the pressure switch pinout and not getting a cel. With certain ecu's you can ground the - wire from the pressure switch to the engine, but the hot wire (D6) has to be connected. What kind of 'trouble' does the pressure switch make?
1SikEagle
04-11-2009 01:02 PM
whophlungpoo
10
10-01-2006 10:52 AM
tinkerbell
01-01-2005 08:00 PM
