How to install asr subframe brace? - Honda-Tech
Old 05-11-2009, 03:01 PM   #1
amej8's Avatar
Default How to install asr subframe brace?
Just got my asr subframe brace for my 99 ex coupe in the mail today (that means it doesn't have the stock backing plates behind the subframe like the Si does). I went to look for a How-To but the only one I could find was the one on PW:JDM. But it can't be the right one because the subframe brace itself looks different from the pictures. And it doesn't say what to do with the other parts that I got along with the brace.
Here's what I got:
I think I have a rough idea on how to install it but I'm still confused as to use what bolts where.
Input?
amej8 is offline   Reply With Quote
Old 05-11-2009, 08:13 PM   #2
BlueIntegraBoy's Avatar
Default Re: How to install asr subframe brace?
BlueIntegraBoy is offline   Reply With Quote
Old 05-11-2009, 09:00 PM   #3
bump nice hardware
k1llak973 is offline   Reply With Quote
Old 05-16-2010, 01:25 PM   #4
NismoTyler's Avatar
Quote:
Originally Posted by BlueIntegraBoy View Post
Thanks for the link. My brace came with a sticker instead of instructions
NismoTyler is offline   Reply With Quote
Old 05-16-2010, 01:36 PM   #5
Ruben19's Avatar
my asr subframe is a bit different. i was able to use my stock lower control arm bolts.
i guess i have the new asr subframe design
Ruben19 is offline   Reply With Quote
Old 05-16-2010, 06:01 PM   #6
Master Detailer
98civdx's Avatar
The new designs allows you to use stock bolts
98civdx is online now   Reply With Quote
Old 05-22-2010, 03:17 PM   #7
NismoTyler's Avatar
stock bolts ftw!
Old 05-22-2010, 07:26 PM   #8
cvcrcr99's Avatar
Google.com would be a nice thing to use as well. This probably has been covered like 8,000 times.
cvcrcr99 is offline   Reply With Quote
Old 05-22-2010, 09:01 PM   #9
xero_xero's Avatar
bump for some clean hardware. can we get some comparison pics of the new and old design?
xero_xero is offline   Reply With Quote
Old 05-23-2010, 03:43 PM   #10
NismoTyler's Avatar
Quote:
New Design
Old 05-23-2010, 03:45 PM   #11
xero_xero's Avatar
props, what brand LCAs are those?
Old 05-23-2010, 04:21 PM   #12
NismoTyler's Avatar
pershiate it man the LCAs are Blox but the logo is so thin it didn't show up in the photos
Old 05-23-2010, 06:31 PM   #13
PSU
formerly DxHatchback
PSU's Avatar
Quote:
Originally Posted by NismoTyler View Post
stock bolts ftw!
Not necessarily.
PSU is offline   Reply With Quote
Old 05-23-2010, 06:59 PM   #14
318 Curves, 11 miles
Vindicator9000's Avatar
The new style brace is different from the one in the instruction manual that was posted. The old style didn't have the L brackets, because the entire thing was cut out of one solid piece of aluminum. I imagine the new style is much cheaper and easier to produce, and would have less waste.
Basically, you use the hex bolts to attach the L-shaped pieces to the back of the brace.
Then, you remove the LCA bolts, line the brace up, and put the LCA bolts back in. Then line up the little backing plates and put the other bolts in. Keep in mind that they're different lengths... that tripped me up at first.
It's actually not a very difficult install, especially if you have an impact driver for the LCA bolts.
Please tell me you have a swaybar for this, and you're not just installing the brace by itself.
Vindicator9000 is offline   Reply With Quote
Old 06-07-2010, 11:54 AM   #15
kristo's Avatar
Bringing this up
Quote:
This would refer to the 'first' brace (EK-RB-01 for EK), the commonly known model like OP has (EK-RB-02) also features separate L-brackets.
Was this new design announced somewhere? I surely missed it.
kristo is offline   Reply With Quote
Reason for ASR brace on EM1 Atomic1 Suspension & Brakes 3 03-16-2015 09:08 AM
Rear subframe bolts HotCheetos Honda Civic / Del Sol (1992 - 2000) 10 12-11-2010 10:07 PM
Suspension Gods answer me this happycorey Suspension & Brakes 19 06-19-2009 04:16 PM
Trying to install rear asr subframe breace on my 00 ITR... killacam661 Acura Integra Type-R 10 04-22-2009 11:47 PM
subframe tear out, just happened, awesome. seowitz Honda Civic / Del Sol (1992 - 2000) 16 05-21-2008 03:56 AM
Tags
00, 94, 98, asr, brace, civic, hardware, honda, instal, install, installation, installing, integra, subframe, tech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
