how to hook up autometer air fuel ratio gauge? - Honda-Tech
Old 04-19-2002, 11:47 PM   #1
Ignitecivic's Avatar
Default how to hook up autometer air fuel ratio gauge?
i just got an air/fuel ratio gauge. i want to know how to hook it up. can anyone help me. appreciate any help.
thanks
Ignitecivic is offline   Reply With Quote
Old 04-20-2002, 12:36 AM   #2
Jonathan_ED3's Avatar
Default Re: how to hook up autometer air fuel ratio gauge? (Ignitecivic)
i'd have no clue. my advice, call them directly...they're really helpful. just tell the secretary lady you need install help and she'll patch you to the 'tech' department
Jonathan_ED3 is offline   Reply With Quote
Old 04-20-2002, 12:56 AM   #3
Default Re: how to hook up autometer air fuel ratio gauge? (hot_EF)
tap it off your ecu or your o2 sensor on your cat.. i dunno what wire it is for you car tho
f0de is offline   Reply With Quote
Old 04-20-2002, 07:08 AM   #4
b16b hatch's Avatar
If it i OBD II then the wire is orange/black for the O2 on connector A the 32 prong one. the ground is the thicker black one and then the power on I used for same one as the stereo ignition. I am not sure on the colors for the OBD I harness.
b16b hatch is offline   Reply With Quote
Old 04-20-2002, 08:14 AM   #5
M.A.R.C.'s Avatar
what car is it? obd1 or 2? If it's 2... just run the wire from the gauge to the ecu... and look for a white wire (might look kinda off white) and tap that. Not sure if it's the same for OBD1... should be though... me thinks. I did mine like this:
- position the gauge and pod on the a-pillar
- run the power, ground and o2 signal wires behind/under the dash
- tapped the accessory plug wire for power, grounded it somewhere, and then ran the signal wire to the panel where the ecu is and then tapped the white wire.
This way u don't have to run wires directly to ur o2 sensor.
Hope that helps.
[Modified by CivicRyda2k, 11:18 AM 4/20/2002]
M.A.R.C. is offline   Reply With Quote
Old 04-20-2002, 04:45 PM   #6
Default Re: how to hook up autometer air fuel ratio gauge? (CivicRyda2k)
it is for a 94 d16z6. i dont know what obd is it.
Old 04-20-2002, 05:42 PM   #7
That would be obdI, I think your best bet would be to tap off the o2 sensor. My old car had a dedicated O2 sensor for my A/f meter.
I have a 93 civic but never had the need for an a/f gauge....
mps9506 is offline   Reply With Quote
Old 04-20-2002, 05:43 PM   #8
mantic6t9's Avatar
Default Re: how to hook up autometer air fuel ratio gauge? (mps9506)
That's obd1, you still want to tap in off your ecu.
mantic6t9 is offline   Reply With Quote
Old 04-20-2002, 05:45 PM   #9
DragII's Avatar
Default Re: how to hook up autometer air fuel ratio gauge? (mantic6t9)
ecu or the sensor itself both work fine.
DragII is offline   Reply With Quote
hooking up air fuel ratio gloshift gage robbrush Honda Civic / Del Sol (1992 - 2000) 1 10-18-2012 02:57 PM
how to install a faze air/fuel ratio gauge sins Honda Civic / Del Sol (1992 - 2000) 1 09-28-2009 11:00 AM
Air/Fuel Ratio Gauge 94JDMcivic Honda CRX / EF Civic (1988 - 1991) 7 01-30-2008 10:29 PM
Oxygen Sensor Color Diagram BoyRacer007 Honda Civic / Del Sol (1992 - 2000) 0 10-25-2006 12:48 AM
99 Accord Air/Fuel Ratio Gauge Installation AccordF23A1 Honda Accord (1990 - 2002) 6 01-04-2004 01:37 AM
Tags
96, accessory, air, autometer, civic, d16z6, fuel, fule, gauge, guage, hondatech, hook, hooking, hookup, ratio
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
