How hard is it to replace a rear motor mount? - Honda-Tech
Old 12-08-2002, 08:10 AM   #1
Civichatch972's Avatar
Default How hard is it to replace a rear motor mount?
Wondering how hard it would be to replace a rear motor mount in my 92 hatch with b18c1 swap? Got the swap a couple of days ago and rear mount seems out. What mount am I going to need a gsr mount or ? and also am I going to need to jack up the motor so I can get to the mount or can I just replace it with out doing that?
Needs some help?
Civichatch972 is offline   Reply With Quote
Old 12-08-2002, 09:15 AM   #2
Bumnah's Avatar
Default Re: How hard is it to replace a rear motor mount? (Civichatch972)
the mount itself is most probably a civic mount. the t bracket in the back which attaches to the motor/trans is from an integra. if you mean to replace the bushing you're probably using your civic rear rubber mount.
i'd pick up some prothane motor mount inserts and put one back there if you are going back there.
i've found the rear mount a pain in the *** to replace. i would most def. pull the motor a little bit. if not take it to a shop. i find paying $50 for labor on this piece is fine with me, and i'm a cheap bastard.
Bumnah is offline   Reply With Quote
Old 12-08-2002, 09:35 AM   #3
dogpile5's Avatar
Default Re: How hard is it to replace a rear motor mount? (Bumnah)
it can be kind of tricky. i would recommend removing the intake manifold support bracket first. then take your time, one of the bolts is easier to access from the top, the other two from the bottom. careful no to damage any of the coolant lines, they are located right next to the motor mount...
dogpile5 is offline   Reply With Quote
Old 12-08-2002, 09:42 AM   #4
Default Re: How hard is it to replace a rear motor mount? (dogpile5)
So that mount on there is a civic mount, I though they would use an Integra mount just like the two mounts that are left and right of the head.
Correct?
Old 12-08-2002, 10:40 AM   #5
Losrocket_'s Avatar
I helped a friend put in a HASport rear drag mount and it was a lot easier than i thought it'd be. The room is a little limited but its really not hard at all.
Losrocket_ is offline   Reply With Quote
Old 12-08-2002, 10:59 AM   #6
Default Re: How hard is it to replace a rear motor mount? (Losrockeeto)
would I have to lift up the motor a little or can I just change it from where its at?
Old 12-08-2002, 12:42 PM   #7
Tofurky's Avatar
you're gonna need to have something support the motor - or have a few friends lift it in the back, and push down on the front... just to keep the pressure off the mount to remove it.
the rear mount is off a civic.
and obviously the rear bracket is off a gsr.
Tofurky is offline   Reply With Quote
Replacing the Rear Crossmember lfajardo Honda Civic / Del Sol (1992 - 2000) 12 09-14-2010 02:14 AM
how do you replace your rear mount on a dc2 JWHATCH23 Acura Integra 3 12-14-2006 08:19 PM
From H-Series to B-series Swap question B18eg-T Honda Civic / Del Sol (1992 - 2000) 4 02-21-2006 01:52 AM
BIG PROBLEM need new motor mounts for H22A EG but stock locatation cut off allwhitehonda Hybrid / Engine Swaps 9 08-19-2004 02:13 PM
motor mount problem help me out asap juicedricer Hybrid / Engine Swaps 4 03-02-2003 04:19 PM
Tags
92, civic, engine, hard, honda, images, ingene, integra, motor, mount, mounts, rear, removing, replace, replacing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
