How to fix broken speedometer. - Honda-Tech
Old 03-16-2011, 01:03 PM   #1
Default How to fix broken speedometer.
I have a 1994 honda civic and when i drive sometimes the speedometer needle does not move or sometimes it goes to outrageous numbers like i could be going 30 mph n it goes all the way to 60 or even 100 what could be the problem?
xjm92x is offline   Reply With Quote
Old 03-16-2011, 04:05 PM   #2
Default Re: How to fix broken speedometer.
wiring is messed up
CHandshuh97EX is offline   Reply With Quote
Old 03-16-2011, 06:04 PM   #3
JDyzzle's Avatar
vehicle speed sensor, its located near the rear or the transmission on top one 10mm bolt holds it in
JDyzzle is offline   Reply With Quote
Old 03-16-2011, 07:16 PM   #4
hannslebo's Avatar
I have this same problem...I do not think it is the speed sensor. I have replaced that, and it still does it. Im thinking its in the wiring behind the cluster?? It is a DX chassis/body, but has a EX cluster. The car runs like normal, vtec still kicks. So any more info on this would be greatly appreciated!
THANKS!
hannslebo is offline   Reply With Quote
Old 03-16-2011, 08:21 PM   #5
ej2b20v's Avatar
clean the plug that goes to the sensor on the tranny. i had the same problem once
ej2b20v is offline   Reply With Quote
Old 03-17-2011, 04:18 AM   #6
russ.shafer's Avatar
do what ej2b20v said .or try a dif cluster if you changed the vss sensor
russ.shafer is offline   Reply With Quote
Old 03-17-2011, 06:19 AM   #7
Do i have to take the car apart to get to the plug or just the cluster?
Old 03-17-2011, 10:11 AM   #8
thecruzs2007@yahoo.com's Avatar
just take the bezel off, take the 4 screws and take the cluster out..
thecruzs2007@yahoo.com is offline   Reply With Quote
Old 03-21-2011, 09:45 PM   #9
ej2b20v's Avatar
its the one that goes form the sensor to a grey plug clean out the grey plug in the inside sometimes it gets coroted
Old 03-21-2011, 10:10 PM   #10
dem0nk1d's Avatar
some times the circuit board goes bad on the rear of the gauge. you'll see this board once you remove the gauge from the cluster housing.
when i bought my car the speedo would randomly work, i changed out the board from a junk yard gauge, and started working right away.
dem0nk1d is offline   Reply With Quote
speedometer not working comptonfinest Honda Accord (1990 - 2002) 1 07-19-2009 08:02 AM
speedometer works on and off. civiccpedx Honda Civic / Del Sol (1992 - 2000) 6 05-18-2007 07:56 PM
Speedometer Problems kuruption0722 Honda Civic / Del Sol (1992 - 2000) 7 11-18-2005 12:08 AM
speedometer Problem 96 accord Findingo Honda Accord (1990 - 2002) 1 08-29-2005 07:53 PM
Speedometer Cable? 89civichatchback Honda CRX / EF Civic (1988 - 1991) 7 07-25-2003 05:16 PM
Tags
1992, 97, broken, civic, del, fix, fixing, gauge, honda, mph, prelude, rsx, sol, speedometer, tach
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
