How does a aftermarket cam gear increase power?
Old 10-20-2009, 09:08 PM
fryman's Avatar
Icon6 How does a aftermarket cam gear increase power?
I was just wondering how does getting an adjustable cam gear increase power?
Also how much hp could it increase in a sohc engine?
Old 10-20-2009, 09:11 PM
roycivic92's Avatar
Default Re: How does a aftermarket cam gear increase power?
not much power, the cam gear is the option to play with your timming. exospeed and bisi are master sohc tuners hit them up to sse if it will help ur set up
fastrxu's Avatar
Adjustable cam gear= not for power. Its for fine tuning timing
Cam= more power over stock depednding on size of lobes
It can increase your jdm points by 10 stars
Old 10-20-2009, 09:15 PM
Colonel Cake Mix
acake em1's Avatar
^^^ haha
yeah op you need an aftermarket cam to have any substantial performance increase with cam gears
Cyberwaste's Avatar
jdm points my ***
cams just sound cool but dont really add mush more then a header unless you get really into it
Old 10-20-2009, 09:20 PM
roycivic92's Avatar
have u guys ever advancet ur timming on ur rides , it feels cool on low end but sucks on top end. or if u playing with nos . for a stock motor is useless it just looks cool.haha
Old 10-20-2009, 09:22 PM
Colonel Cake Mix
acake em1's Avatar
function before form haha
but they do look cool
Old 10-20-2009, 09:27 PM
fastrxu's Avatar
Of course as in any mod you have to follow through with something else
i.e. Intake alone is ok header alone is ok exhaust alone is ok... But you pair them up to compliment each other and they net more power.
You cant just throw in a cam and call it a day. (not if you wanna make the most out of it)
You pair it up with high comp pistons, performance im, and a good tune and its a different animal.
There is no magical mod like that, other than fi and even then you gotta finish it off with a tune
Old 10-20-2009, 09:32 PM
Colonel Cake Mix
acake em1's Avatar
exactly. the tune is always the most important part
Old 10-20-2009, 09:33 PM
fryman's Avatar
I always thought it was more for looks than anything lol.
Well while were on the topic of camshafts I have another question.
If you upgrade the camshaft and pistons+rods+rings you can get a higher redline right or is more needed?
I don't mean to sound like a newbie but I am new to this since I have no experience upgrading engine internals.
Old 10-20-2009, 09:35 PM
Colonel Cake Mix
acake em1's Avatar
if u do all that u are prolly gonna wanna chip ur ecu and with that u can increase ur redline
someone correct me if im wrong
Old 10-20-2009, 09:41 PM
fastrxu's Avatar
To use upgraded cam you gotta upgrade the valvetrain regardless and that too will help apinning your engne at a higher redline
You can increase your redline with a "chip" any time but to do it safely i would do all you mentioned plus balance the crankshaft and a block guard
Old 10-20-2009, 09:44 PM
Colonel Cake Mix
acake em1's Avatar
yeah... there is a lot more work involved than just throwing in a cam and gears and calling it a day.. you mess with one system you better mess with the others
Old 10-20-2009, 09:51 PM
fryman's Avatar
Whats a block guard?
Old 10-20-2009, 09:53 PM
roycivic92's Avatar
i would say a block girdle
Old 10-21-2009, 06:46 AM
ExospeedAMcrx's Avatar
OK alot of misinformation in this thread.
Camgear lets you adjust the cam positioning to find the most efficient area for power. Each setup will have its own preference on how a cam is tuned and for the powerband.
An aftermarket cam's goal is to bring in more air into the engine. More air means more power. The cam design allows that to happen by lift and duration combinations. Thats why you have different stages. And those different stages work in combination with certain compressions, engine displacement, etc. You just cant mix and match big cams on stock motors, etc.
All upgrades have to work together in some way. More air you have coming in the engine, whether its using a bigger cam, different intake manifold, etc., the more fuel it'll want to work efficiently.
Exospeed and Bisimoto both offer camshafts for different engines. We arent a tuner though, we just developed our camshafts just like other manufacturers. Bisimoto does offer dyno tuning at their facility.
Back to the original question: If a cam gear makes more power. A Cam gear is a tuning tool. The part itself doesnt give more power. The Cam gear lets you adjust a camshaft to gain more power by fine tuning. At the same time, if not done properly, you can lose power.
Old 10-26-2009, 11:04 AM
Sales@Bisimoto.com's Avatar
That is probably the best explanation for what you can "gain" with an adjustable cam gear
black91
09-05-2005 12:13 AM
ityab0y
02-15-2005 07:09 AM
tgreaves
12-10-2003 01:20 PM
94civicx
12-16-2001 10:18 AM
azn_outlaw
10-27-2001 02:19 PM
Quick Reply: How does a aftermarket cam gear increase power?
