How do you take off the "rotor"/"rotor button"??? - Honda-Tech
Old 03-04-2003, 08:08 PM   #1
civicdream's Avatar
Default How do you take off the "rotor"/"rotor button"???
I was gonna do a tune up (first time by myself) and i couldn't get the rotor off. Haynes manual says something about a "retaining screw", but I didn't see it. Thanks.
P.S. Now my damn Check Engine light is on, WTF????
Allen
[Modified by civicdream, 4:11 AM 3/5/2003]
civicdream is offline   Reply With Quote
Old 03-04-2003, 08:12 PM   #2
Solbros Owns Me
Evs-One's Avatar
Default Re: How do you take off the "rotor"/"rotor button"??? (civicdream)
there's just one screw holding it on....right in the middle. Should be a gold looking phillips head
edit- you might have to rotate the engine until you see it. You have to look from the top of the engine, or bottom because it goes in the side...hard to explain, but you;ll see
[Modified by Emerica, 8:13 PM 3/4/2003]
Evs-One is offline   Reply With Quote
Old 03-04-2003, 08:15 PM   #3
civicdream's Avatar
Default Re: How do you take off the "rotor"/"rotor button"??? (Emerica)
Dude, I don't see it. Also there is this black casing under the rotor button, which cannot be removed unless the rotor is removed. I didn't see a screw.
95 Ex coupe. Sorry forgot to add that earlier.
Old 03-04-2003, 08:32 PM   #4
Happyman's Avatar
uhhh the rotor isn't held on by a screw? lol. There should be holes though. 2 to be exact that are not occupied. Get a bolt that fits and put it in one of the holes and tighten it down a little. Then do the other hole. Keep going back and forth. Also try to get a penetrant in there. Prolong works well. If you still can't get it off then take it to a shop and see if they have a drum puller. I think you can use a drum puller on rotors(not sure).
Happyman is offline   Reply With Quote
Old 03-04-2003, 08:39 PM   #5
Hollywoood's Avatar
There should just be a screw, screwed into the side of the shaft. Like somone said earlier, you may have to bump the engine over to rotate it correctly! Remove the screw and the rotor slides right off!! As far as the CEL I have no idea.......
Ryan
Hollywoood is offline   Reply With Quote
Old 03-04-2003, 08:54 PM   #6
Default Re: How do you take off the "rotor"/"rotor button"??? (Happyman)
Hey man, just thought you'd like to know that he is talking about the "rotor" in the distributor, not on the front of the vehicle. BWAHAHAHAHAHAAA!!!!!!!!!!!!!!
93eg-EKhybrid is offline   Reply With Quote
Old 03-04-2003, 09:04 PM   #7
EKhatch's Avatar
Ye , one gold screw. I know it's a pain in the *** to try and turn the motor over and look for the screw at the same time, just be patient. As for the check engine light, when your done wiht the rotor thing reset the ECU and go from there.
EKhatch is offline   Reply With Quote
Old 03-04-2003, 09:32 PM   #8
DarkSubRosa's Avatar
lmfao
DarkSubRosa is offline   Reply With Quote
Old 03-05-2003, 04:19 AM   #9
96HatchB18's Avatar
The easiet thing to do is to have a buddy give the motor a quick crank (turn the key real quick till it tries to start and let go real quick). While he is doing this you should have your head down in behind the distributor. You will see it. It is a gold screw. It may take a few cranks to get it to line up.
96HatchB18 is offline   Reply With Quote
Old 03-05-2003, 04:22 AM   #10
96HatchB18's Avatar
As for the CEL, while you were messing with all of this trying to get the rotor off, did you accidentally unplug any plugs or connections. Try to pull a code. Let us know what you get.
ps someone buy my car http://hometown.aol.com/accord32/
Old 03-05-2003, 05:16 AM   #11
Happyman's Avatar
Default Re: How do you take off the "rotor"/"rotor button"??? (96HatchB18)
oooooooooo thought you were talking about the brake rotor
First Homepage and I am clueless!! civicdream General Discussion and Debate 12 11-08-2002 08:34 PM
Goin to Miami game tomorrow, but should I feel guitly? civicdream General Discussion and Debate 2 10-25-2002 09:30 PM
My Summer Road Trip! civicdream General Discussion and Debate 27 04-06-2002 12:25 AM
Pics of Black Civic with White Wheels civicdream Honda Civic / Del Sol (1992 - 2000) 33 01-21-2002 02:26 AM
Black/Green interiour color scheme. civicdream Honda Civic / Del Sol (1992 - 2000) 6 01-06-2002 02:35 AM
Tags
1992, 240sx, 93, 96, button, civic, distributor, honda, middle, off, pull, remove, removing, rotor, rotorbutton, screw, taking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
